silentdan Posted July 20, 2012 Report Share Posted July 20, 2012 (edited) I was looking around ebay and stumbled upon this brake kit. http://www.ebay.ca/i...=item336e8109cd Just like to get any opinions on this cause I am currently looking to replace the brakes on my 2010 DJ SXT and its time to go with something diffrent than the crapy OEM ones. Cheers! Edited July 20, 2012 by silentdan Quote Link to comment Share on other sites More sharing options...
larryl Posted July 20, 2012 Report Share Posted July 20, 2012 I have had good luck putting them on my 09 but they were not from this seller I also used Wagner Ceramic pads Quote Link to comment Share on other sites More sharing options...
silentdan Posted July 20, 2012 Author Report Share Posted July 20, 2012 I have had good luck putting them on my 09 but they were not from this seller I also used Wagner Ceramic pads Thanks for the reply man.I am really interested in a setup like this and hopefully it will be better than the oem brakes.I will do more diging around and make sure I buy the right stuff. Cheers! Quote Link to comment Share on other sites More sharing options...
onecrazyfoo4u Posted July 26, 2012 Report Share Posted July 26, 2012 I would be concerned since they aren't name brand or anything. Probably not much better quality than the oem ones. I good set of brakes for all 4 corners should cost you closer to $400 (about $100 for good ceramic pads front/rear) and (about $300 for all 4 rotors). You'll probably be back to square one if you get cheap brakes on ebay. Stick to name brands like Powerslot, Wagner, Hawk, EBC, etc. Journey_SeXT 1 Quote Link to comment Share on other sites More sharing options...
Mcgusto82 Posted July 31, 2012 Report Share Posted July 31, 2012 I would be concerned since they aren't name brand or anything. Probably not much better quality than the oem ones. I good set of brakes for all 4 corners should cost you closer to $400 (about $100 for good ceramic pads front/rear) and (about $300 for all 4 rotors). You'll probably be back to square one if you get cheap brakes on ebay. Stick to name brands like Powerslot, Wagner, Hawk, EBC, etc. Where do YOU buy brakes from?? Ever been to pep boys? Autozone? Their best brake pads top out around 60$ the set. WITH the lifetime guarantee. Only the dealer has the balls to charge that high for brakes. Quote Link to comment Share on other sites More sharing options...
onecrazyfoo4u Posted July 31, 2012 Report Share Posted July 31, 2012 Where do YOU buy brakes from?? Ever been to pep boys? Autozone? Their best brake pads top out around 60$ the set. WITH the lifetime guarantee. Only the dealer has the balls to charge that high for brakes. Well that's because it's autozone brand brake pads. If you want the good quality Hawk or EBC pads it's going to cost you about $100-120 for all 4 corners. You can get whatever brand you want...but I sure wouldn't go with Ebay generic no-name brakes. Quote Link to comment Share on other sites More sharing options...
