mr_chief Posted July 25, 2012 Report Share Posted July 25, 2012 (edited) Hello all, I have a problem with acceleration with my car. When I started to drive the car self turn to right. The suspension is correctly set (checked twice for sure on a computer diagnostics). Maybe someone have the same as me? Is this a problem with tires (orginal from the begining)? Journey 2011, 3.6 CREW imported to Europe/Poland. 10000 miles Edited July 25, 2012 by mr_chief Quote Link to comment Share on other sites More sharing options...
bramfrank Posted July 25, 2012 Report Share Posted July 25, 2012 Possibly a dragging brake caliper? Bad tires? (try rotating them from side to side (front left exchange with front right and the same with the rears) - a bad tire will cause the problem to reverse, so it will pull left). Alternatively simply do a front-to-back rotation - if a front tire is a problem it will be less so, being in back. Quote Link to comment Share on other sites More sharing options...
redtomatoman Posted July 26, 2012 Report Share Posted July 26, 2012 Is the problem really just torque steering? Hard acceleration can cause a feeling of the vehicle wanting to wander. I am not a mechanic or an expert driver so I don't know a lot about the finer points of torque steering tendencies. My understanding is that torque steering forces change depending on engine torque, suspension, and steering combinations. Depending how much you accelerate and which way you are turning, that will affect the torque steer direction. Or maybe torque steer is always to the same direction, not sure. Obviously, a constant pulling to the right can be a million different things. If it is significant, I think you need to take it to the dealer. Immediately. Steering is pretty important. So are brakes and tires as bramfrank suggests as possible causes above. Peace. Quote Link to comment Share on other sites More sharing options...
bramfrank Posted July 26, 2012 Report Share Posted July 26, 2012 Not likely, since the Journey uses a transverse mounted engine. Quote Link to comment Share on other sites More sharing options...
bigtsr Posted July 27, 2012 Report Share Posted July 27, 2012 All the fwd Chrysler products I have driven have demostrated torque steer to some degree, you should try driving Caliber SRT4 in stock configuration. Quote Link to comment Share on other sites More sharing options...
Mcgusto82 Posted August 4, 2012 Report Share Posted August 4, 2012 On 7/26/2012 at 4:22 PM, bramfrank said: Not likely, since the Journey uses a transverse mounted engine. That's actually the reason for torque steer. And you'll only see this on a FWD car. The AWD journeys shouldn't have any torque steer. Quote Link to comment Share on other sites More sharing options...
