Kumho Tires
walker
Understand that the tires that came with your new car were not designed by Kumho, Michelin, Goodyear, Bridgestone or any other tire manufacturer. They were designed by Chrysler. If your new car came with a set of Kumho's, Kumho made the tire but they made it to the specifications set by Chrysler. The OEM tires that came with your car can’t be replaced (which is a good thing) after they’ve worn out. And they will wear out much sooner than they should. This is because virtually all auto manufacturers specify very soft rubber which means they wear out too fast. You can buy what you think is the same tire, but it will have a different model number when sold by a tire store. Auto manufacturers do this because they want that new car to have the smoothest ride possible, even at your expense of having to buy a new set of tires at half the mileage you should have to. When you test drive that brand new car and it rides very, very smoothly you’re more likely to buy it. You’ll find out how fast the tires wear out much later, and when you do you’ll blame it on the tire maker. Don't blame the tire maker, blame the vehicle manufacturer.
Edited by jkeaton
