sexyRTboi Posted September 4, 2012 Report Share Posted September 4, 2012 I've been having some issues with my stereo in my 2012 DJ R/T with the upgraded stereo system (not sure if that has anything to do with it) It seems to constantly "skip" or cut out - doesnt matter if im listening to the Sat Radio, AM/FM, or with my cell phone plugged in - at first it was a quirk ... now its just flat out annoying ! Is there a software upgrade or something I need to have done to resolve this issue? Is anyone else having the same problem? Quote Link to comment Share on other sites More sharing options...
redtomatoman Posted September 4, 2012 Report Share Posted September 4, 2012 How often does it happen? Mine will cut for like a half second every 30 mins or so. I think its just a quirk of the stereo system. Lebowski knows what causes it, I believe. Can't remember what he posted regarding this behavior. Peace. Quote Link to comment Share on other sites More sharing options...
sexyRTboi Posted September 4, 2012 Author Report Share Posted September 4, 2012 I would say, depending on the day .. it could cut out or "skip" a dozen times an hour ... or could just be a few times a day. It is a daily thing though. I'm also noticing in the past few days that my doors seem to rattle with any kind of bass (bass is turned about mid-way ... not MAXED) ... the rattle seems to be coming from the top of the door panal near the lock (not the handle lock .. the pop up lock) on both front doors. Quote Link to comment Share on other sites More sharing options...
redtomatoman Posted September 4, 2012 Report Share Posted September 4, 2012 Not sure about the doors rattling, maybe some insulation would help or new door speakers that can handle the bass better than the stock alpines? As for the skipping, maybe the TSB below would help you. It says CD and applies to the 4.3 radio, but you could bring this to the dealers attention. I would take your DJ to the dealer and complain. You should also record the skipping behavior so that you are sure that the tech knows what he is trying to fix. You may need a new radio or new amplifier. Not sure. Peace. TSB NUMBER: 08-048-11 REV. A GROUP: Electrical DATE: December 20, 2011 SUBJECT: RHA And REB Radio Software Enhancements OVERVIEW: This bulletin involves upgrading the software on the RHA or REB Radio. MODELS: 2011-2012 (JC) Journey **2011-2012 (LD) Charger** NOTE: This bulletin applies to JC vehicles built prior to **October 4, 2011 (MDH 1004XX) and LD vehicles built prior to July 25, 2011** equipped with UCONNECT TOUCH 4.3 CD/MP3 (sales code RHA) or UCONNECT TOUCH 4.3S CD/MP3/SAT (sales code REB). NUMBER: 08-048-11 REV. A GROUP: Electrical DATE: December 20, 2011 SYMPTOM/CONDITION: · **When the ignition is first turned on, the audio volume is very high.** · **CD audio glitch and/or audio drop out for 0.2 seconds.** · No display and no audio on radio. · The driver's heated seat soft key is grayed out on the radio display. · CD skips repeatedly while playing. · CD jumps tracks after cranking the engine, turning the radio off and then on, and/or after depressing the stop and then play soft key. · In USB playback mode a blank screen, or the last displayed screen, is displayed when the ABC soft key is pressed. · An iPod Nano connected in USB mode may fail to play and/or the Pause and Play keys are reversed on the radio display. · Multiple instances of the same Sirius Game Zone entry may be displayed. · Intermittently, the back-up chime sounds continuously once vehicle is put into forward gear, instead of shutting off. DIAGNOSIS: If a customer’s VIN is listed in VIP or your RRT VIN list, perform the repair. For all other customers that describe the symptom/condition, perform the Repair Procedure. PARTS REQUIRED: Qty. Part No. Description **AR (1) 68147629AB REB Update Disc (version 11.41.6) for JC** **AR (1) 68147630AB RHA Update Disc (version 11.41.6) for JC** **AR (1) 68169945AA REB Update Disc (version 11.40.6) for LD** **AR (1) 68169943AA RHA Update Disc (version 11.40.6) for LD** Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted September 4, 2012 Official Dodge Support Report Share Posted September 4, 2012 I've been having some issues with my stereo in my 2012 DJ R/T with the upgraded stereo system (not sure if that has anything to do with it) It seems to constantly "skip" or cut out - doesnt matter if im listening to the Sat Radio, AM/FM, or with my cell phone plugged in - at first it was a quirk ... now its just flat out annoying ! Is there a software upgrade or something I need to have done to resolve this issue? Is anyone else having the same problem? Boi, Here is the latest TSB that may apply to your issue depending on your radio. I agree that you should take it to the dealer for diagnosis even if this TSB does not apply. NUMBER: 08-030-12 REV. B GROUP: Electrical DATE: July 12, 2012 SUBJECT: RHA And REB Radio Software Enhancements OVERVIEW: This bulletin involves upgrading the software on the RHA or REB Radio. MODELS: 2011 - 2012 (LX) 300 2011 - 2012 (JC) Journey 2011 - 2012 (LD) Charger NOTE: This bulletin applies to JC vehicles built between May 1, 2011 (MDH 0501XX) and March 22, 2012 (MDH 0322XX). LD/LX vehicles built between May 1, 2011 (MDH 0501XX) and March 27, 2012 (MDH 0327XX) that are equipped with UCONNECT TOUCH 4.3 CD/MP3 (sales code RHA) or UCONNECT TOUCH 4.3S CD/MP3/SAT (sales code REB). SYMPTOM/CONDITION: · USB/CD skips while playing. · Radio changes stations on it's own. · Radio locks up intermittently or fully inoperative. · Radio cuts in and out, resets on it's own or completely inoperative. · Diagnostic trouble code (DTC) U0147 - Lost Communication With Telematics Gateway. · Radio mutes or Intermittently mutes. · Radio Display goes blank. NUMBER: 08-030-12 REV. B GROUP: Electrical DATE: July 12, 2012 · When the ignition is first turned on, the audio volume is very high. · CD audio glitch and/or audio drop out for 0.2 seconds. · The driver's heated seat soft key is grayed out on the radio display. · CD skips repeatedly while playing. · CD jumps tracks after cranking the engine, turning the radio off and then on, and/or after depressing the stop and then play soft key. · In USB playback mode a blank screen, or the last displayed screen, is displayed when the ABC soft key is pressed. · An iPod Nano connected in USB mode may fail to play and/or the Pause and Play keys are reversed on the radio display. · Multiple instances of the same Sirius Game Zone entry may be displayed. · Intermittently, the back-up chime sounds continuously once vehicle is put into forward gear, instead of shutting off. Quote Link to comment Share on other sites More sharing options...
Lebowski Posted September 4, 2012 Report Share Posted September 4, 2012 Does this TSB apply to European models? Because I've been suffering with these problems for a year and both the dealer and fiat spain say there's no fix. Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted September 4, 2012 Official Dodge Support Report Share Posted September 4, 2012 Does this TSB apply to European models? Because I've been suffering with these problems for a year and both the dealer and fiat spain say there's no fix. I do not know the answer to that question as I do not have access to Fiat updates on European models. I am copying the bottom of the bulletin where it lists international dealers but it is listed under Dodge only. I do not see why a dealer could not simply order the disk and do the update but, again, I do not know the process that European dealers use over there. PARTS REQUIRED: Qty. Part No. Description AR (1) 68147629AC REB Update Disc (version 12.6.13) for JC AR (1) 68147630AC RHA Update Disc (version 12.6.13) for JC AR (1) 68169945AB REB Update Disc (version 12.7.12) for LD AR (1) 68169943AB RHA Update Disc (version 12.7.12) for LD AR (1) 68191370AA RHA Update Disc (version 12.7.2) for LX AR (1) 68191371AA REB Update Disc (version 12.7.2) for LX NOTE: Dealer will order the update disc via Exchange Order Process. The core charge will not apply. Only one update disc is required for each radio (RHA and REB) and vehicle (JC, LX and LD) combination. Each disc may be used to service multiple vehicles. NOTE: ** International dealer will order the update disc via the ERES order process. The core charge will not apply. Only one update disc is required for each radio (RHA and REB) and vehicle (JC, LX and LD) combination. Each disc may be used to service multiple vehicles. ** Quote Link to comment Share on other sites More sharing options...
Lebowski Posted September 4, 2012 Report Share Posted September 4, 2012 Thank you, I'll ask the dealer again. Quote Link to comment Share on other sites More sharing options...
mortalalliance Posted September 4, 2012 Report Share Posted September 4, 2012 (edited) sexyRTboi, I had the exact same issue with my 2012 SXT several months ago. At that time there was an older TSB which addressed some 2011 models. I had the dealer service my vehicle with that TSB and everything turned out great. The TSB DodgeCares posted is a revised (updated) version of what I had done. I recommend printing the TSB and mentioning it to your dealer when you take it in for service. The dealer will probally need to order the disc for the update, and once they get that in everything should be peachy. Also I recommend writing down your saved radio stations on Sirius and/or FM/AM as the firmware update will wipe everything. Wasn't the biggest hassle to just set everything up again, but still.... Edited September 4, 2012 by mortalalliance Quote Link to comment Share on other sites More sharing options...
Lebowski Posted September 6, 2012 Report Share Posted September 6, 2012 I contacted Fiat Spain through their web page, sending them a video of the problem and the TSB details. They called me back and told me they'll contact the dealer. To be continued... Quote Link to comment Share on other sites More sharing options...
Lebowski Posted September 13, 2012 Report Share Posted September 13, 2012 And the reply of customer service is that my radio is up to date and, looking at this video of my radio, according to them it works fine. If a radio that doesn't start from time to time is fine, this is my last Fiat. Quote Link to comment Share on other sites More sharing options...
Lebowski Posted September 21, 2012 Report Share Posted September 21, 2012 Yesterday they called me from the dealership: they wanted the car to check software versions (according to their previous answer that they're up to date they knew them already, maybe they didn't), and one day later they call me telling they have an update. On Monday I'll have it applied. Crossing fingers. Quote Link to comment Share on other sites More sharing options...
rolly Posted September 22, 2012 Report Share Posted September 22, 2012 Yesterday they called me from the dealership: they wanted the car to check software versions (according to their previous answer that they're up to date they knew them already, maybe they didn't), and one day later they call me telling they have an update. On Monday I'll have it applied. Crossing fingers. Good luck! Quote Link to comment Share on other sites More sharing options...
Mcgusto82 Posted September 22, 2012 Report Share Posted September 22, 2012 <-- crossing my fingers for you Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted September 24, 2012 Official Dodge Support Report Share Posted September 24, 2012 Yesterday they called me from the dealership: they wanted the car to check software versions (according to their previous answer that they're up to date they knew them already, maybe they didn't), and one day later they call me telling they have an update. On Monday I'll have it applied. Crossing fingers. Hopefully they update it and it solves the problem. Quote Link to comment Share on other sites More sharing options...
Lebowski Posted September 24, 2012 Report Share Posted September 24, 2012 The technician that should do the update is on sick leave, so I'll have to wait until Tuesday. Quote Link to comment Share on other sites More sharing options...
Lebowski Posted September 25, 2012 Report Share Posted September 25, 2012 Update done. They also flashed the hands-free and the abs modules. It's too early to say if it solved the problem of the radio not starting, the clock going too fast or the mp3 skipping, but at first sight everything else hasn't improved: When playing an mp3 from the CD it doesn't show the artist name (this feature was broken with the first update, it worked when the car was new). Some mp3s display a bogus duration (either too long or too short, the duration shown changes randomly when switching sources). Only the first 3-4 character of station names are shown. I'm not impressed. Quote Link to comment Share on other sites More sharing options...
Lebowski Posted September 26, 2012 Report Share Posted September 26, 2012 Oh, and not unexpectedly, search by song/by artist still doesn't work (it just shows a very limited selection of what's available). Quote Link to comment Share on other sites More sharing options...
Lebowski Posted October 18, 2012 Report Share Posted October 18, 2012 The dealership called me for a new update (or maybe it's the same, Fiat wouldn't even tell them what it is supposed to fix), and I can confirm that, not unexpectedly, all the defects in message #17 and #18 are still there. Quote Link to comment Share on other sites More sharing options...
RickyCheung Posted October 18, 2012 Report Share Posted October 18, 2012 Update done. They also flashed the hands-free and the abs modules. It's too early to say if it solved the problem of the radio not starting, the clock going too fast or the mp3 skipping, but at first sight everything else hasn't improved: When playing an mp3 from the CD it doesn't show the artist name (this feature was broken with the first update, it worked when the car was new). Some mp3s display a bogus duration (either too long or too short, the duration shown changes randomly when switching sources). Only the first 3-4 character of station names are shown. I'm not impressed. I can tell you that the mp3 duration problem isn't your stereo's fault. It should be your mp3 file itself. I've had the same problems on certain songs on a Mercedes, BMW, and smart car stereo display. The problem is usually solved if you rip songs off your CD using iTunes instead of other programs. Quote Link to comment Share on other sites More sharing options...
Lebowski Posted October 18, 2012 Report Share Posted October 18, 2012 (edited) Well, all other players I tried show the duration correctly. Edit: and the fact that even in your Mercedes/BMW/etc. this feature doesn't work correctly doesn't mean that the uconnect is right, it only means that they probably contracted the player to the same (or similar) lousy supplier. Edited October 19, 2012 by Lebowski Quote Link to comment Share on other sites More sharing options...
RickyCheung Posted October 19, 2012 Report Share Posted October 19, 2012 Well, all other players I tried show the duration correctly. Edit: and the fact that even in your Mercedes/BMW/etc. this feature doesn't work correctly doesn't mean that the uconnect is right, it only means that they probably contracted the player to the same (or similar) lousy supplier. Same, it's quite odd because it can show the proper duration on my computer/home stereo/iPod/phone. But I've solved the problem on the uconnect and other car systems by ripping songs using iTunes. I've been using WMP to rip songs and I think that's what have been giving me problems. Quote Link to comment Share on other sites More sharing options...
