allwxflyer Posted September 17, 2012 Report Share Posted September 17, 2012 Hi all, Today I was thinking of going to the Dealer on Monday to have the transmission fluid on my 2011 3.6L V6 checked. Usually have it done monthly. Then I thought - I'm tired of doing this AND, "Why pay $50+ bucks for a stupid tranny dipstick to check it myself?" The last time I was at the Dealer having the fluid checked, the Tech let me take a photo of the "Factory" dipstick assy. For those who haven's seen one; its a small dipstick (a bit longer than a ballpoint pen), attached to a 6 ft. long cable with a Tee-handle, marked off in 10mm steps . I got to thinking, the markings on the factory unit were on a 10mm scale, from 0 to 120mm. I looked at my oil dipstick and figured I could reproduce that 10mm scale on it. Heck, it was worth a try. So, as I was checking my oil, I was wondering if the oil dipstick would fit in the tranny filler tube where the fluid is checked. Well, let me tell you -- it fits nicely thankyou. First off, clean off the oil dipstick so any motor oil doesn't mix with the trans. fluid. Insert the dipstick into the tranny tube until it bottoms out. The distance to the bottom of the pan is about 16 to 16 14", but you'll feel it contact the bottom of the pan. I downloaded a Millimeter scale from the Net and made a hard copy in order to transfer the markings onto the dipstick. (Don't use the "shrink to fit" option on the printer or the scale will be off) I marked one edge of the dipstick every 10mm (upto 120mm) according to the scale, using a Dremel Tool with a small cutting disk to notch the dipstick and notched the 50mm and 100mm marks on both edges of the dipstick. Now I have one tool (dipstick) for checking 2 systems, the oil/engine system, and the transmission. The procedure took longer to explain than the actual project, but it kept me busy and away from the wife's "honeydo" list. :hide: I have a set of photos to go along with the project, so if anyone wants a copy of them (in zip format) just send me an e-mail at johnk1rc@verizon.net and I'll send them to you. If you have any questions, just ask. I'll answer them as best I can. John, Dracut, MA. Sparkyssxt and ghostone 2 Quote Link to comment Share on other sites More sharing options...
rsemak Posted April 15, 2013 Report Share Posted April 15, 2013 What is the "warm" level of the transmission supposed to be at? What millimeter mark? Quote Link to comment Share on other sites More sharing options...
allwxflyer Posted November 6, 2013 Author Report Share Posted November 6, 2013 When the trans fluid is up to temp., the level should be between 50 and 60 MM. I've included in the .ZIP file, a chart of fluid level vs fluid temp. Quote Link to comment Share on other sites More sharing options...
senah Posted November 8, 2013 Report Share Posted November 8, 2013 On 11/6/2013 at 12:38 AM, allwxflyer said: When the trans fluid is up to temp., the level should be between 50 and 60 MM. I've included in the .ZIP file, a chart of fluid level vs fluid temp. Is your transmission leaking? What is prompting you to check it? It is a sealed system. What are you using to measure the tranny fluid temp? Quote Link to comment Share on other sites More sharing options...
bigtsr Posted November 8, 2013 Report Share Posted November 8, 2013 Tranny temp shows in the EVIC display. Quote Link to comment Share on other sites More sharing options...
combatjourney Posted May 4, 2014 Report Share Posted May 4, 2014 Email sent for pictures of Tranny Dipstick. Thanks Quote Link to comment Share on other sites More sharing options...
bramfrank Posted May 4, 2014 Report Share Posted May 4, 2014 That last comment can be taken a couple of different ways . . . . jkeaton 1 Quote Link to comment Share on other sites More sharing options...
Journey_SeXT Posted May 4, 2014 Report Share Posted May 4, 2014 On 5/4/2014 at 8:30 AM, bramfrank said: That last comment can be taken a couple of different ways . . . . jkeaton 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted May 5, 2014 Report Share Posted May 5, 2014 On 5/4/2014 at 8:30 AM, bramfrank said: That last comment can be taken a couple of different ways . . . . LOL!!! Journey_SeXT 1 Quote Link to comment Share on other sites More sharing options...
bigtsr Posted May 5, 2014 Report Share Posted May 5, 2014 Maybe he's just confused! lol Quote Link to comment Share on other sites More sharing options...
