bigunclejethro Posted December 29, 2013 Report Share Posted December 29, 2013 The one I bought is a K&N Series 69 Typhoon part number 69-2546ts Link to comment Share on other sites More sharing options...
Camper Posted January 18, 2014 Report Share Posted January 18, 2014 Just replaced air paper filter with K&N one, and discovered small (short) tube made from felt attached to the main intake at the bottom of filter box (inside the box) . What is the reason for that short tube? Can it be removed without voiding the warranty? Does it restrict the air flow, even for the paper filter? Link to comment Share on other sites More sharing options...
2late4u Posted January 19, 2014 Report Share Posted January 19, 2014 for $301.00 ill just have to get use the stock box and just do without the extra gas mileage.... Link to comment Share on other sites More sharing options...
onecrazyfoo4u Posted January 19, 2014 Report Share Posted January 19, 2014 Just remove that short felt tube...I did. I think its there to keep the noise down a bit. Link to comment Share on other sites More sharing options...
travis9935 Posted January 24, 2014 Report Share Posted January 24, 2014 I'd like to see some detailed pics! How is the fitment? FYI people the intake can be had for $235 online. I was gonna buy one for the 12' Avenger that I had, bought a Magnaflow exhaust instead. Link to comment Share on other sites More sharing options...
Journey_SeXT Posted January 25, 2014 Report Share Posted January 25, 2014 Just remove that short felt tube...I did. I think its there to keep the noise down a bit. Why would you remove something if you are unsure what it does? Link to comment Share on other sites More sharing options...
Phoenix1984 Posted February 11, 2014 Report Share Posted February 11, 2014 Things I the intake are generally to reduce turbulence, and reduce noise. My old ranger had a cone in the tube for that purpose that went from 3" to 1" with holes in it. I took it out. As long as there isn't a wire connected to it it will be fine. Link to comment Share on other sites More sharing options...
Totemus Posted March 17, 2014 Report Share Posted March 17, 2014 There have been 2 K&N part mentioned in neighbor threads: K&N 69 Series Typhoon Intake Systems - 69-2546TS and K&N 69-2543TTK Which one is a better fit, if anybody knows? Link to comment Share on other sites More sharing options...
Darkpaw Posted March 25, 2014 Report Share Posted March 25, 2014 69-2546TS is for the 3.6 (2011+ models). 69-2543TTK is for the 3.5 (models up to 2010). Check the "vehicle application guide" of each to see what it applies. Personally, I'm trying to find a way to custom-build the K&N I pulled off my SRT8 before I traded it in. Will take some work, but I'm determined to fit it in there. I'm not buying another kit when I already have a massive filter and really just need to customize some kind of aluminum case for it and a 4" (OD) pipe to the existing straight-pipe section. Totemus 1 Link to comment Share on other sites More sharing options...
travis9935 Posted March 25, 2014 Report Share Posted March 25, 2014 Can anyone verify that the 69-2546TS kit will fit on a journey Link to comment Share on other sites More sharing options...
jkeaton Posted March 25, 2014 Report Share Posted March 25, 2014 Can anyone verify that the 69-2546TS kit will fit on a journey Says its for an Avenger. Link to comment Share on other sites More sharing options...
Darkpaw Posted March 25, 2014 Report Share Posted March 25, 2014 It is designed for the Avenger, but since the engine bays are nearly identical (both build on same platform) it "should" fit. I thought I saw mention earlier in the thread that "bigunclejethro" had put one in his 2013. If so, this implies that it should fit. Link to comment Share on other sites More sharing options...
travis9935 Posted March 25, 2014 Report Share Posted March 25, 2014 I owned a 2012 Avenger and the plastic snorkel part is did between the two. But otherwise pretty close. Link to comment Share on other sites More sharing options...
cskmom Posted March 26, 2014 Report Share Posted March 26, 2014 (edited) What about the CAI for the dodge journey 2014 CVP 2.4L? Anyone have the part #? Edited March 26, 2014 by cskmom Link to comment Share on other sites More sharing options...
carritt11 Posted February 24, 2015 Report Share Posted February 24, 2015 Alright all, I'm a brand new 2015 journey owner. I had a 2011 avenger that I had the k&n intake on. I removed it from the car and put on the journey and it does work. The hoses connect the same and bottom bolts are the same the only difference is that the grille is higher on the journey so the last bolt does not connect. Between the 2 bottom bolts and the hoses, it isn't going anywhere.. Sounds awesome. Link to comment Share on other sites More sharing options...
dhh3 Posted February 25, 2015 Report Share Posted February 25, 2015 I filled out the form. After reading through the entire thread, it didn't seem like anyone did it. I did have the mentioned MOPAR CAI on my Nitro. I love the sucking sound a CAI makes, but for some reason the 3.7 did not do this. But, it did look cool. Link to comment Share on other sites More sharing options...
Jhdez317 Posted March 6, 2015 Report Share Posted March 6, 2015 just sent a request, i hope they make one soon! Link to comment Share on other sites More sharing options...
dhh3 Posted March 6, 2015 Report Share Posted March 6, 2015 (edited) I have the latest, and last Mopar Accessory Catalog for the DJ. No CAI is listed. To get an accessory now for the DJ, you have to go to the Dealer. They have an Accessory Section in their parts manual. I have always asked for an Accessory Catalog when purchasing a vehicle. When I bought my DJ, I asked for one, and was told that Parts had them. Went to Parts, and was told that they no longer print them. He looked around, and finally found one for me. There is not much in it. There are some available on ebay. Edited November 22, 2015 by dhh3 Link to comment Share on other sites More sharing options...
Johnnyh Posted November 21, 2015 Report Share Posted November 21, 2015 I totally think the importance of a CIA in most applications is a visual thing. Now a days engineers know the importance of a free flowing intake and exhaust for power and economy. I have put K&N filters in all my cars, trucks and Harley's for the last 25 years. I really don't know if I realize more power or MPG but its cheaper to run one and clean it annually compared to purchasing a new one yearly. I have had hot rod cars and Harley's with all types of intake systems but think you are throwing money at nothing putting $350.00 into a CIA for a simple family SUV. Spend the money on bigger brakes or something that keeps your family safer. jkeaton 1 Link to comment Share on other sites More sharing options...
bigunclejethro Posted February 8, 2016 Report Share Posted February 8, 2016 Carritt I did the same thing, and added a bit of sheet metal to make a good seal with the hood when closed. I don't care what anyone else says, I struggled to get more than 17mpg before I put the intake on. Now I consistently get close to 20, and when I went on a long trip mostly highway driving I saw around 27mpg. Just my $0.02. carritt11 1 Link to comment Share on other sites More sharing options...
carritt11 Posted February 9, 2016 Report Share Posted February 9, 2016 Carritt I did the same thing, and added a bit of sheet metal to make a good seal with the hood when closed.. I thought about doing that but just never took the time to try it. Can you post a pic? I'm curious to see how it turned out. Link to comment Share on other sites More sharing options...
bigunclejethro Posted February 12, 2016 Report Share Posted February 12, 2016 Carritt, here are some pics. Just a bent piece of sheet metal riveted to the original shield. carritt11, SeanTacular and jkeaton 3 Link to comment Share on other sites More sharing options...
carritt11 Posted February 12, 2016 Report Share Posted February 12, 2016 Carritt, here are some pics. Just a bent piece of sheet metal riveted to the original shield. Nice, that's kind of how I thought of doing it. But I also thought about having a piece attach by the cowl on top of the grille so the air is guided to the air filter more. Link to comment Share on other sites More sharing options...
Jeremiah860 Posted March 26, 2016 Report Share Posted March 26, 2016 OK guys new to the dodge family ive always driven a toyota but i decided to make the jump to dodge and recently purchased a 2014 Dodge Journey SXT 3.6L From my understanding of what i read and the couple pictures i saw the K&N 69-2546TS Air Intake that fits on the 2014 Dodge Avenger will fit on the Dodge Journey 3.6L almost identical. AM i correct? Also What do you guys think of the small upgrade in a CAI? Do you guys think its worth it to get the CAI or should i just stick with the K&N air filter? Link to comment Share on other sites More sharing options...
