jeremy0213 Posted October 1, 2012 Report Share Posted October 1, 2012 (edited) Last week I ordered the following: Most sites did not list the following kit as compatible with my '11 Dodge Journey Crew but it is listed for '09 & '10 Dodge Journeys and if I am not mistake the fog light housings are the same. Guess I will find out soon. Spyder Auto FL-P-DM05-HL Projector Fog Light http://www.amazon.co...ils_o01_s00_i00 The next kit was listed for my Journey but is no longer available(?) which makes me worry a little bit. "Slim" HID Kit by Kensun with Xenon Lights, H3, 5000K" http://www.amazon.co...ils_o02_s01_i00 Both should arrive today or tomorrow. Installation of the HID kit looks to be straightforward and the new fog light housings looks to be an exact swap. The "Angel Eyes" part of the new fog lights look to be wired separately and I want the Angel Eye ring to always be on when the Journey is on regardless of if the fog lights (or any other lights) are actually on or not. Anyone have any suggestions of where can I (easily) wire the rings to achieve this? Hopefully somewhere near the fog lights already. Any other help would be appreciated as well, Thank you. Edited October 1, 2012 by jeremy0213 Quote Link to comment Share on other sites More sharing options...
Mcgusto82 Posted October 1, 2012 Report Share Posted October 1, 2012 (edited) Take a picture when u put them in. I be It'lll look sweet. Edited October 1, 2012 by Mcgusto82 Quote Link to comment Share on other sites More sharing options...
bigtsr Posted October 1, 2012 Report Share Posted October 1, 2012 Last week I ordered the following: Most sites did not list the following kit as compatible with my '11 Dodge Journey Crew but it is listed for '09 & '10 Dodge Journeys and if I am not mistake the fog light housings are the same. Guess I will find out soon. Spyder Auto FL-P-DM05-HL Projector Fog Light http://www.amazon.co...ils_o01_s00_i00 The next kit was listed for my Journey but is no longer available(?) which makes me worry a little bit. "Slim" HID Kit by Kensun with Xenon Lights, H3, 5000K" http://www.amazon.co...ils_o02_s01_i00 Both should arrive today or tomorrow. Installation of the HID kit looks to be straightforward and the new fog light housings looks to be an exact swap. The "Angel Eyes" part of the new fog lights look to be wired separately and I want the Angel Eye ring to always be on when the Journey is on regardless of if the fog lights (or any other lights) are actually on or not. Anyone have any suggestions of where can I (easily) wire the rings to achieve this? Hopefully somewhere near the fog lights already. Any other help would be appreciated as well, Thank you. Do you have the '11 DJ parts pdf file? It gives you illustrated pic of everything. Quote Link to comment Share on other sites More sharing options...
AstralRT Posted October 1, 2012 Report Share Posted October 1, 2012 ..... I want the Angel Eye ring to always be on when the Journey is on regardless of if the fog lights (or any other lights) are actually on or not. I did this in my Integra a few years back when I put in Angel Eye projector headlights with Halos. I used 3M wire taps to connect the Halo ring wires to the side marker wires. It was a simple 5 min job once I knew which wire to tap and the halos now come on when I turn on the running lights. If you want yours on all the time, you might want to check the high beam/DRL power wire to determine if it can handle the extra drain for the halos in the fogs, the halos are just two small leds each so I don't imagine much strain on the system. Not sure what affect it have on HID headlights though. Quote Link to comment Share on other sites More sharing options...
jeremy0213 Posted October 1, 2012 Author Report Share Posted October 1, 2012 I did this in my Integra a few years back when I put in Angel Eye projector headlights with Halos. I used 3M wire taps to connect the Halo ring wires to the side marker wires. It was a simple 5 min job once I knew which wire to tap and the halos now come on when I turn on the running lights. If you want yours on all the time, you might want to check the high beam/DRL power wire to determine if it can handle the extra drain for the halos in the fogs, the halos are just two small leds each so I don't imagine much strain on the system. Not sure what affect it have on HID headlights though. Thanks for the advice. And yes bigtsr, I do have that pdf and will dig through it to see if I find something. AstralRT, thanks for the suggestions. I will check to see if any of the side markers are always on. The High/DRL won't work because they are not always on. The high beams/day time running lights go off when the low beams are on or when the turn signal is on but thanks anyway. The ideas are headed in the right direction Quote Link to comment Share on other sites More sharing options...
AstralRT Posted October 2, 2012 Report Share Posted October 2, 2012 The only other thing I can think of is to hook it up direct to the battery with a switch mounted inside the cabin (with a fuse somewhere on the line between the battery and the switch for safety. You might be able to do a google search to see how people used to install those underbody neon lights and such for some ideas. I'm sure there has to be someone that did some light installs to always be on and not hooked up to a dash mounted switch. Just some thoughts. I personally prefer having them connected to the running lights. Quote Link to comment Share on other sites More sharing options...
Mcgusto82 Posted October 2, 2012 Report Share Posted October 2, 2012 The DJ parts PDF is a mix of current DJ parts and the older parts. In the fog lights section, it shows the 09 fog lights, but further down the line, it has the 4.3 as the radio head unit. Who knows how accurate that manual is. Quote Link to comment Share on other sites More sharing options...
rnhiga Posted July 10, 2013 Report Share Posted July 10, 2013 Hi Jeremy, Did this 09 foglight fit on your Journey ? I'd like to replace the psx24w fog light (from 2013 journey) to h10 housing. Thanks, Rafael Quote Link to comment Share on other sites More sharing options...
