2012 trans feels as if it is slipping
paxmaster2000
i have a 2012 se avp. love it. the only issue i seem to have is that it feels like it shifts wierd. i took it the dealer and they said that it was fine.
the service manager said that the trans is like other trans . he explained the trans works like the trans on a gocart. there is like belts that grab pulleys for different gears.
he also stated that it doesnt shift any gears but there is a program in the engine that makes the engine misfire to make it feel like it is shifting gears.
is there any truth to this? also the trans is a sealed unit and the fluid is $99 per gallon.
who's the service advisor the lot boy!!!!!!!!!!!!
This reminds me of when my 11' caravan started having its misfiring problem.
They sent me with one one of their "mechanics" on a test drive, Who turned out to be their lot boy. Lol.
He even told me that the reason the caravan isn't smooth is because it's not an import. Like an odessey or a sienna.
"now those cars have power". No BS, he actually said that.
That was the last time I went to that dealer.
Edited by Mcgusto82
Doesn't sound like any of that is true. An SE/AVP should have the 4 speed, and this is how the transmission works:
http://www.allpar.co...sions/41TE.html
It's also not a sealed unit. There is clearly a dipstick on the driver side under the hood.
The only fluid you should use is Mopar brand ATF+4 and it is about $7-8/qt.
The break-in period for mine was about 9,000 miles, and then it smoothed out. At first it felt strange, like it was bucking, torque convertor was vibrating, shifted like a manual with a delay between gears, etc. Now it's fine. This transmission doesn't exactly feel refined or modern since it has been around since 1989.
I had an '03 Intrepid with a variant of this transmission and it felt very similar. Traded that car in with 231,000 original miles, when it started having trouble getting into gear first thing in the morning (among a list of other glitches). In hindsight, it could've been doing that because the fluid was original, except for a 5 qt pan drop & filter performed @ 60,000 miles. Based on that experience I'm willing to bet the Journey 4 speed will go the long haul as long as you don't do any neutral drops.
Edited by tstone
  • Official Dodge Support
Pax,
They should also make sure the trans has been updated with the latest software.
NUMBER: 18-024-12
GROUP: Vehicle Performance
DATE: August 10, 2012
SUBJECT:
Flash: MIL Illumination P0108 - Manifold Absolute Pressure Sensor Circuit High And
Transmission Shift Improvements
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Powertrain Control
Module (PCM) with new software.
MODELS:
2012 (JC) Journey
NOTE: This bulletin applies to vehicle equipped with a 3.6L or 2.4L engine (sales
code ERB or ED3) and a 6 speed automatic transmission (sales code DG2)
built before June 28, 2012 (MDH 0628XX).
SYMPTOM/CONDITION:
The customer may experience any of the following:
· Malfunction Indicator Lamp (MIL) illumination. Upon further investigation the
Technician may find that P0108 - Manifold Absolute Pressure Sensor Circuit High
has been set active or stored 3.6L engine.
· 1 - 2 upshift clunk or bump 2.4L & 3.6L engines
· 3 - 4 harsh upshift at closed throttle after a WOT stab in 1st or 2nd gear. 2.4L & 3.6L
engines
· 4 - 5 upshift clunk or bump 2.4L & 3.6L engines
· 5 - 6 upshift clunk or bump 3.6L engine
· 6 - 5 downshift clunk or bump 3.6L engine
· 6 - 4 downshift clunk or bump 3.6L engine
· RPM Fluctuating or Jerking feeling while operating in cruise control. Condition is
more noticeable when the vehicle is going up and down grades.2.4L & 3.6L
engines
· 1 - 2 harsh upshift going down a grade 2.4L engine
Pax,
NUMBER: 18-024-12
SUBJECT:
OVERVIEW:
MODELS:
2012 (JC) Journey
SYMPTOM/CONDITION:
engines
engines
It is SO frustrating to me that this update is not available for my 2011. I am having the exact rough shifting issues as described in this TSB.
so when should they mention that there is an update? my car has close to 8k miles on it. i don't drive the car all that much because i have my 00 ram sport.
I would mention it to them. Can't imagine they will mention it to you if they do not believe there is even an issue with the transmission. Or better yet, I would take it somewhere else if another dealer is in your area.
i brought my car to the dealer last month with the problem. i just got off the phone with another dealer and they said there is an update and they will take care of it for me.
Hopefully is will solve the issue that you are experiencing.
well the car shifts so much better. when i went to drop it off the service tech made me show that there was an update. after he seen that i knew what
i was talking about he agreed that there was an update. pick the car up the next day because i couldnt stay. the car seems to have longer in the rpm range.
THANK YOU. now only if i can get them to fix my heat and air fan speed.
Hold up. This bulletin says
"This bulletin applies to vehicle equipped with a 3.6L or 2.4L engine (sales code ERB or ED3) and a 6 speed automatic transmission..."
Since when did the SE / AVP model with the 2.4L have a 6 speed?
It is worded incorrectly but it applies to both engine/trans configurations.
