Xphyle Posted July 31, 2008 Report Share Posted July 31, 2008 Just changed the oil on my Journey after the computer told me to do so. 3400 miles. So how the F do you reset the warning? I've tried the method in the owners manual: 1. Turn key in ignition to "On" without starting the car... 2. Depress accelerator fully 3 times within 10 seconds 3. Turn key in ignition to "LOCK". Did this like 10 freakin times to no avail. Computer kept giving me the "Oil Change Required" each time I started the car. What am I doing wrong? Anyone? Thanks! Xphyle Quote Link to comment Share on other sites More sharing options...
RickC Posted July 31, 2008 Report Share Posted July 31, 2008 I just did the same last week, and it took on the 1st try... I'm not sure why it isn't working for you. Rick Quote Link to comment Share on other sites More sharing options...
wyoram Posted July 31, 2008 Report Share Posted July 31, 2008 You might be turning the key all the way off instead of into the lock position. I had a Chevy that was the same way to clear the oil change thing. I could not figure it out for the life of me. Then I realized I was turning the key all the way off. Quote Link to comment Share on other sites More sharing options...
2009journey Posted August 1, 2008 Report Share Posted August 1, 2008 I had the same problem, was driving me crazy..... then depressed accelerator 4 times instead of 3 out of desperation and it worked!!!! Quote Link to comment Share on other sites More sharing options...
Canada_Jay Posted January 13, 2009 Report Share Posted January 13, 2009 I tried many times.... finally I did? Key ON, push the pedal 1, 2, 3 (and hold it down), wait to see no "Oil Change" indicator and then Lock. What a stupid reset. Quote Link to comment Share on other sites More sharing options...
rozwell911 Posted January 26, 2009 Report Share Posted January 26, 2009 I tried many times.... finally I did? Key ON, push the pedal 1, 2, 3 (and hold it down), wait to see no "Oil Change" indicator and then Lock. What a stupid reset. Be gald we don;t own a BMW. You either need a 300.00 reset tool, or take it into the dealer to get it reset. I am glad i can reset it on my own in the Journey. Quote Link to comment Share on other sites More sharing options...
JourneyMan71 Posted April 17, 2009 Report Share Posted April 17, 2009 My 2003 Saturn had a button inside the fuse box under the hood. It also had a similar key type reset. PapaG 1 Quote Link to comment Share on other sites More sharing options...
GreenMtns Posted May 10, 2009 Report Share Posted May 10, 2009 I had the same problem, was driving me crazy..... then depressed accelerator 4 times instead of 3 out of desperation and it worked!!!! I've tried everything mentioned in here at least 5 times and nothing has worked for me yet. It just keeps telling me to take it to the dealer. It seems there must be a simple reset somewhere that did not get into the manual. If anybody has found it PLEASE lets us know. Al Quote Link to comment Share on other sites More sharing options...
jbauto3 Posted May 15, 2009 Report Share Posted May 15, 2009 I've tried everything mentioned in here at least 5 times and nothing has worked for me yet. It just keeps telling me to take it to the dealer. It seems there must be a simple reset somewhere that did not get into the manual.If anybody has found it PLEASE lets us know. Al You have to do it all the way down & slow Quote Link to comment Share on other sites More sharing options...
larryl Posted May 15, 2009 Report Share Posted May 15, 2009 Yes it does work Key "on" engine NOT running Push accelerator down 3 times slowly within 10 seconds-it will reset I change my own oil & reset it myself no problem-unless you have a malfunction Quote Link to comment Share on other sites More sharing options...
GreenMtns Posted May 16, 2009 Report Share Posted May 16, 2009 Yes it does workKey "on" engine NOT running Push accelerator down 3 times slowly within 10 seconds-it will reset I change my own oil & reset it myself no problem-unless you have a malfunction Well after I and many others tried to get the warning to go out I took back to the dealer. The service manager came out and was going to show how easy it is. After many, and I do mean many tries, he went back to the shop and got a tech. Tech sat down Tech turned the key to "on" Tech SLAMMED the throttle to the floor 3 times FAST Tech turned the key to "off" Tech said" sometimes you have to do this twice" Tech then repeated the above Warning when away I think it was scared. It may never come back again :o Karl McPeak and aukfan33 2 Quote Link to comment Share on other sites More sharing options...
sdeveau Posted May 19, 2009 Report Share Posted May 19, 2009 We had the same problem! My husband tried 4 times and couldn't get it to work. We had to take it to the dealer who tried several times before it would reset. Very tricky. Very annoying. Quote Link to comment Share on other sites More sharing options...
ckl Posted May 22, 2009 Report Share Posted May 22, 2009 I'm going to do an oil change tonight. I'll see if the reset procedures work on mine. I think, from reading the above posts, the accelerator pedal needs to be pushed ALL THE WAY DOWN completely and that the key position must be in the right position. If it doesn't work, I'll just hook up my OBDII scan tool and do a reset there and see if it works. Quote Link to comment Share on other sites More sharing options...
GreenMtns Posted May 23, 2009 Report Share Posted May 23, 2009 I'm going to do an oil change tonight. I'll see if the reset procedures work on mine. I think, from reading the above posts, the accelerator pedal needs to be pushed ALL THE WAY DOWN completely and that the key position must be in the right position.If it doesn't work, I'll just hook up my OBDII scan tool and do a reset there and see if it works. Darn...I can never find my OBDII scan tool when I need it. (What's a OBDII scan tool anyway) :D Quote Link to comment Share on other sites More sharing options...
ckl Posted May 25, 2009 Report Share Posted May 25, 2009 Okay, here's an update. I reset the oil change light the first try. It's kind of confusing because it doesn't tell you when you've successfully reset it so I'm sitting there wondering whether or not it actually worked or not. Anyway, here's the exact procedure I followed: 1. Insert key. turn to ON position. Watch gauges do their self test. 2. Press accelerator pedal all the way down until it hits the stopper. Do this 3 times... one second apart each time. You do not need to slam the pedal. 3. After you've pressed the pedal for the third time. Wait a second. 4. Turn key back to Lock position. 5. Sit and wonder if it worked. take key out. 6. Put key back in, start car. check to see if oil reset indicator shows up. That worked for me. OBDII scan tool is a device that hooks up to your vehicle that can read any problem codes that are generated by your car's computer. Codes that normally show up as a check engine light on your dashboard. The scan tool has the ability to clear the codes, which resets the check engine light. If the problem is not fixed, however, the code will be thrown again, which will cause the check engine light to come on again. As for the oil change, it's probably the easiest one I've done in a while. The oil filter is in a super easily accessible location. My other car, a japanese model, has the oil filter in an extremely hard to access location. Below the intake manifold and just above the exhaust manifold. Hence, I have to wait until the car cools down before I can change the oil. And because it's hard to access, some of the oil drains out of the filter while I'm trying to snake it out of the engine compartment... creating a huge mess. Argh! ApinoA 1 Quote Link to comment Share on other sites More sharing options...
Snow_Runner Posted August 23, 2009 Report Share Posted August 23, 2009 My wife had the Journey in for an oil change, and when she came home she told me that the "Change Oil" indication was still there. So out I go with manual in hand for about an hour, and it would not reset?? I looked at the receipt from the dealer and noticed that the oil quantity was half a litre less than every other oil change. Took it to the dealer the next day and showed him the oil quantity, and they added the difference, and voila, I was able to reset the oil change indicator first try?? Is it possible that it will not reset if the oil level is not correct after the oil is dumped and refilled? If you were to change your oil at home, and you were parked on a sloped driveway, maybe it wouldn't reset? Any thoughts?? RP Quote Link to comment Share on other sites More sharing options...
JourneyMan71 Posted September 17, 2009 Report Share Posted September 17, 2009 My wife had the Journey in for an oil change, and when she came home she told me that the "Change Oil" indication was still there. So out I go with manual in hand for about an hour, and it would not reset??I looked at the receipt from the dealer and noticed that the oil quantity was half a litre less than every other oil change. Took it to the dealer the next day and showed him the oil quantity, and they added the difference, and voila, I was able to reset the oil change indicator first try?? Is it possible that it will not reset if the oil level is not correct after the oil is dumped and refilled? If you were to change your oil at home, and you were parked on a sloped driveway, maybe it wouldn't reset? Any thoughts?? RP It sounds logical, I have taken my Journey to the dealer for my oil changes. I use RP and just pay them for the change and filter. With the lifetime warranty it is best to keep a nice paper trail Quote Link to comment Share on other sites More sharing options...
wpeets Posted December 9, 2009 Report Share Posted December 9, 2009 I am thinking of purchasing an OBDII scan tool. Which one do you have and have you found it useful? Where is the port for it on the Dodge Journey? Thanks in advance for the assistance. OBDII scan tool is a device that hooks up to your vehicle that can read any problem codes that are generated by your car's computer. Quote Link to comment Share on other sites More sharing options...
jaymista Posted December 10, 2009 Report Share Posted December 10, 2009 Check out this web site ... www.auterraweb.com/ Quote Link to comment Share on other sites More sharing options...
jaymista Posted December 10, 2009 Report Share Posted December 10, 2009 Well after I and many others tried to get the warning to go out I took back to the dealer. The service manager came out and was going to show how easy it is. After many, and I do mean many tries, he went back to the shop and got a tech.Tech sat down Tech turned the key to "on" Tech SLAMMED the throttle to the floor 3 times FAST Tech turned the key to "off" Tech said" sometimes you have to do this twice" Tech then repeated the above Warning when away I think it was scared. It may never come back again :o How is an ordinary layman supposed to know stuff like this? It happened to me last month and I took it to the dealer and they fixed it but I didn't see how he did it. These vehicles of today are getting so you really have to know what you are doing to work on your vehicle. You even have to know how to run a computer on your car. And the hourly fees keep going up! Quote Link to comment Share on other sites More sharing options...
brwengel Posted December 11, 2009 Report Share Posted December 11, 2009 How is an ordinary layman supposed to know stuff like this? It happened to me last month and I took it to the dealer and they fixed it but I didn't see how he did it. These vehicles of today are getting so you really have to know what you are doing to work on your vehicle. You even have to know how to run a computer on your car. And the hourly fees keep going up! Yeah sometimes my dealer forgets to reset mine as well, and I can never remember how to do it. Luckily the procedure is in the owners manual. Quote Link to comment Share on other sites More sharing options...
jondjf Posted April 26, 2010 Report Share Posted April 26, 2010 Just changed the oil on my Journey after the computer told me to do so. 3400 miles. So how the F do you reset the warning? I've tried the method in the owners manual: 1. Turn key in ignition to "On" without starting the car... 2. Depress accelerator fully 3 times within 10 seconds 3. Turn key in ignition to "LOCK". Did this like 10 freakin times to no avail. Computer kept giving me the "Oil Change Required" each time I started the car. What am I doing wrong? Anyone? Thanks! Xphyle This proceedure seemed to work for me and clear the message on my 2010 RT AWD Quote Link to comment Share on other sites More sharing options...
BUGS Posted April 26, 2010 Report Share Posted April 26, 2010 a small piece of painter's masking tape over the indicator works too. Write the mileage on it for the next the oil change and when you get to that reading remove the tape...voila - the indicator says it is time to change the oil. Then repeat. Quote Link to comment Share on other sites More sharing options...
ApinoA Posted January 19, 2012 Report Share Posted January 19, 2012 Hi all, many thanks ... The procedure worked at the first try! redtomatoman 1 Quote Link to comment Share on other sites More sharing options...
crockejw Posted September 14, 2013 Report Share Posted September 14, 2013 Just changed the oil on my Journey after the computer told me to do so. 3400 miles. So how the F do you reset the warning? I've tried the method in the owners manual: 1. Turn key in ignition to "On" without starting the car... 2. Depress accelerator fully 3 times within 10 seconds 3. Turn key in ignition to "LOCK". Did this like 10 freakin times to no avail. Computer kept giving me the "Oil Change Required" each time I started the car. What am I doing wrong? Anyone? Thanks! Xphyle Not sure why it doesn't work. I just tried it on my wife's Journey, and it worked first time. Quote Link to comment Share on other sites More sharing options...
