Fog in headlight lens
Hey all, anyone else have this problem.....
I have an 09 R/T with about 43,000 miles
Suddenly I have developed the problem of having moisture collecting inside the lens of the passenger headlight assembly. It covers the entire assembly, heavier on the bottom half to clear on the very top. I have checked for cracks in the lens (NONE, not even scratched), checked the vent tubes to see if they became blocked (nope) and even ran water over the top of the assemble by the clear/black seam (no leaks, see no water going in). If I remove all the bulbs and park in the sun, the lens clears up, for awhile, but then returns in a few days.
Ideas??????
ALSO, maybe for DodgeCares, I have a lifetime warranty from Dodge. Since its not damaged would it be covered if I need to replace it???
Thanks in advance.
I'd say the vent tunes are clogged. Id take the headlight off and physically clear the tubes.
The dealer would probably clear the lens by doing the exact same thing you did.
Then you'd have to come back for a second visit b4 they'd really rolled up their sleeves.
