skuntbhuddy Posted December 10, 2012 Report Share Posted December 10, 2012 Can someone help on torque specs for the 2012 DJ's. I have the 19"s for summer but just installed 17" steelie's on Hankook ipike RW11's 225/65/17 and would like to know the specific torque rate. Quote Link to comment Share on other sites More sharing options...
Rubberdude88 Posted December 10, 2012 Report Share Posted December 10, 2012 Here's a link to TireRack... you will need to know your stud size. http://www.tirerack.com/wheels/tech/techpage.jsp?techid=107 Cheers Quote Link to comment Share on other sites More sharing options...
skuntbhuddy Posted December 10, 2012 Author Report Share Posted December 10, 2012 I'm using the same studs that came with my stock 19" which I'm not to sure of. Quote Link to comment Share on other sites More sharing options...
OhareFred Posted December 12, 2012 Report Share Posted December 12, 2012 The 19 inch tires on an 09 are torqued at 100 foot pounds Quote Link to comment Share on other sites More sharing options...
black2011 Posted January 12, 2013 Report Share Posted January 12, 2013 I have the 19" Chrome Clad wheels on my 2011, is the torque spec still 100lbs? I see that most manufacturers recommend 80-90 depending on size of the vehicle. 100lbs just sounds a little high. Can anyone help me with this. Thanks! Quote Link to comment Share on other sites More sharing options...
webslave Posted January 12, 2013 Report Share Posted January 12, 2013 My owner's manual specs 95 ft lbs for the 19" wheels on my '13 R/T... Quote Link to comment Share on other sites More sharing options...
bramfrank Posted January 12, 2013 Report Share Posted January 12, 2013 Accuracy of the wrench, surface condition of the fasteners, including corrosion, oils and moisture makes the number an approximation, at best. 90, 95, 100 or even 110 means nothing. It just gets you 'in the range'. Quote Link to comment Share on other sites More sharing options...
black2011 Posted January 14, 2013 Report Share Posted January 14, 2013 Thank you. That's all helpful information. Quote Link to comment Share on other sites More sharing options...
