reynolds72450 Posted December 21, 2012 Report Share Posted December 21, 2012 I have the Infinity system and was wondering has anybody or can you remove the factory 8" sub in the back. I was wanting to put a aftermarket in there with a sub amp? Will it work? Quote Link to comment Share on other sites More sharing options...
reynolds72450 Posted December 21, 2012 Author Report Share Posted December 21, 2012 Also which sub? I don't know how much air space is in there also to make the right sub work? Quote Link to comment Share on other sites More sharing options...
onecrazyfoo4u Posted December 31, 2012 Report Share Posted December 31, 2012 (edited) I'm sure it would be an improvement. It wouldn't hit any harder if you use the stock amp, but it could at least sound cleaner I'm sure. Has anyone swapped out the stock sub for a better brand? Also, what ohm rating would the sub need to be to hook up to the stock amp? 2, 4, or 8 ohm? Edited December 31, 2012 by onecrazyfoo4u Quote Link to comment Share on other sites More sharing options...
