m2j Posted December 27, 2012 Report Share Posted December 27, 2012 I would like to know if a 255/50R 19 will be ok to replace my current 225/55 19 tires. Thank you Quote Link to comment Share on other sites More sharing options...
onecrazyfoo4u Posted December 31, 2012 Report Share Posted December 31, 2012 I'm pretty sure a 255 is too wide of a tire for the stock 19" wheels. Quote Link to comment Share on other sites More sharing options...
riashaw Posted January 22, 2013 Report Share Posted January 22, 2013 i've got 255/50 19" on currently - they were no problem to get on the stock rims. they feel a lot nicer, a lot stiffer than the stock tires. the wider tires grip into any groove in the road, so be wary of that if i crank the wheel and back up there is a slight rub - they're not too tall, they're too wide and i think rub slightly against the strut, i'll probably go to a 245 next time i think Quote Link to comment Share on other sites More sharing options...
onecrazyfoo4u Posted January 23, 2013 Report Share Posted January 23, 2013 The diameter seems about the exact same...it's just much wider. The stock 225/55 tire is 8.85" wide. The 255/50 is 10" wide (requires rim width of 7-9"). 245/50 is 9.64" wide. What is the rim width of the stock 19" rims? Do you rub all the time with 255/50/19 tires? Or just when you do full wheel crank left or right? Quote Link to comment Share on other sites More sharing options...
