Tonysir Posted February 10, 2013 Report Share Posted February 10, 2013 Hey guys. I'm new to this, but I looked through the forum didn't really see anything like the issue I'm having. Just picked up my journey about a month ago, first thing I did was change headlights and fogs to hid's. They all worked fine from day one, got the relay for the headlights and everything. After a heavy snowfall we had in Toronto I noticed one fog, my driver side flickering and then went out completely. I check the blub the balist they all work fine if I switch them to the passenger side. There is not voltage going to the harness on the driver side. I unhooked the hid kit and put the regular bulb back it... Still no light but I did see it flicker for a few seconds and then nothing. I thought maybe a fuse but I can't seem to find one. Does anyone know what the problem is or could be??? All help would be greatly appreciated.. I would really rather not have to run all new power wires to the fogs but if I can't figure it out them I'm going to have to . Quote Link to comment Share on other sites More sharing options...
Journey_SeXT Posted February 11, 2013 Report Share Posted February 11, 2013 Welcome to the forum! This thread may help address your issue....http://www.dodgejourneyforum.com/topic/2916-upgraded-to-hid-headlamps/ Quote Link to comment Share on other sites More sharing options...
Tonysir Posted February 11, 2013 Author Report Share Posted February 11, 2013 thanks for the welcome to the forum! i looked through the thread you sent but i don’t see anything regarding the issue im having. i called the dealer and they told me the fogs are not on a fuse. they are controlled but the ECU. but for one to be working and one to be off is some sort of wiring issue. i will have to dig deeper in to this. but when i checked the connector, wire before the connector and the wire higher up behind the headlight i still had no power. i might just run a relay and power it from the switch on the signal lever inside the vehicle. does anyone have the wiring diagram? i have no problem testing it to find the correct wire just though i could make life a little easier Quote Link to comment Share on other sites More sharing options...
