davidlb512 Posted February 16, 2013 Report Share Posted February 16, 2013 (edited) Taken from http://www.sylvania.com/en-us/applications/automotive-lighting-systems/Pages/lrgallbulbs.aspx?year=2012&qual=&model=1223&make=24 2012 DODGE Journey. Low beam headlamp - 9006 9012(H.I.R. bulbs)c.o.:burgandy25 High beam headlamp - 9005 9011(H.I.R. bulbs)c.o.:burgandy25 Parking light - 3757A Front turn signal - 3757A Rear turn signal - 992 (7440A) Rear turn signal - 3157A Tail light - LED Tail light - 3157 Stop light - LED Stop light - 3157 High mount stop light - LED Fog/Driving light - 2504 License plate - 168 Back up light - 7440 Back up light - 3157 Front sidemarker - 168 Glove box - 194 Map light - LED Map light - 578 Trunk/Cargo area - 579 Edited February 20, 2013 by davidlb512 Quote Link to comment Share on other sites More sharing options...
Mcgusto82 Posted February 18, 2013 Report Share Posted February 18, 2013 👍👍 Quote Link to comment Share on other sites More sharing options...
burgandy25 Posted February 18, 2013 Report Share Posted February 18, 2013 For the headlight... 9005 (high beams) can be replaced by 9011 HIR bulbs with a simple trim of the socket tabs, 9006 (low beams) can be replace by 9012 HIR bulbs with a trim of the tabs also.. for more info visit: store. candle power . com. I have these and they are great... Quote Link to comment Share on other sites More sharing options...
davidlb512 Posted February 19, 2013 Author Report Share Posted February 19, 2013 For the headlight...9005 (high beams) can be replaced by 9011 HIR bulbs with a simple trim of the socket tabs, 9006 (low beams) can be replace by 9012 HIR bulbs with a trim of the tabs also.. for more info visit: store. candle power . com. I have these and they are great... Looks great burgandy25. I wonder tho, what the reasoning behind making the HIR bulbs, and not match the other factory bulb types. Anyway, do you trim the bulbs, or the bulb housing on the headlight? And if you trim the housing on the headlight, does it make it to where you can't go back to a 9005 or 9006 bulb? Quote Link to comment Share on other sites More sharing options...
burgandy25 Posted February 19, 2013 Report Share Posted February 19, 2013 Looks great burgandy25. I wonder tho, what the reasoning behind making the HIR bulbs, and not match the other factory bulb types. Anyway, do you trim the bulbs, or the bulb housing on the headlight? And if you trim the housing on the headlight, does it make it to where you can't go back to a 9005 or 9006 bulb? Great question to ask! you trim the tap that is attached to the bulb! so no long term modifications to the headlight housing is necessary So when you buy a 9011 or 9012 you have to trim one of the three tabs on the bulb itself. Look in this link to see what I mean. http://ep.yimg.com/ca/I/yhst-91565365470012_2243_878180 You can use an HIR bulb then go back to 9005 or 9006 bulbs if you don't want HIR again. The HIR bulbs are awesome to say the least. More (usable) Lumens down the road, and longer lasting bulbs; who doesn't want that? and not that much more expensive over regular bulbs. I recommend them to anyone looking to upgrade. Quote Link to comment Share on other sites More sharing options...
burgandy25 Posted February 19, 2013 Report Share Posted February 19, 2013 Looks great burgandy25. I wonder tho, what the reasoning behind making the HIR bulbs, and not match the other factory bulb types. Anyway, do you trim the bulbs, or the bulb housing on the headlight? And if you trim the housing on the headlight, does it make it to where you can't go back to a 9005 or 9006 bulb? to answer your question about matching to 9005 and 9006 bulbs, I do not fully know but I do know that the HIR bulbs do NOT have silver caps on the end of the bulbs like 9005/9006 bulbs do. And they are used in the last Gen. Dodge Viper and Corvettes, along with other cars that had projectors but don't have HIDs. But they are the same wattage as stock 9005/9005, so you will not fry the wiring or anything... 9005=65W bulb - (9011 (HIR1)) bulb is also 65W 9006=55W bulb - (9012 (HIR2)) bulb is also 55W Quote Link to comment Share on other sites More sharing options...
davidlb512 Posted February 20, 2013 Author Report Share Posted February 20, 2013 That's good to hear! I'll add those part numbers to the list then. Quote Link to comment Share on other sites More sharing options...
