TSB 19-002-08 for Grind / Rub noise while turning
The service bulletin for grind / rub noise while turning is released. TSB 19-002-08
For those of you that followed my advice for the interim fix and had the dealer overfill your reservoir, the next time you are at the dealer tell them to apply the TSB and get a taller reservoir as this will ensure the noise does not return.
The TSB for exhaust howl / growl will be released shortly. If you're also affected by that issue keep your eyes on that thread for the TSB number.
Thank you for your patience
