jojogg Posted March 20, 2013 Report Share Posted March 20, 2013 I need to install a parking sensor, however I do not know how to connect the the power cord to the socket inside the trunk rear driver side. I checked the trunk and looks like I need remove the left side plastic cover. Thank you in advance. Quote Link to comment Share on other sites More sharing options...
bigtsr Posted March 20, 2013 Report Share Posted March 20, 2013 I don't believe your going to find any freebie manuals other than parts anywhere,if you do let us know about it. You have remove the WHOLE 1/4 panel of plastic unless you can just pry out the rear section to connect to 12 vdc outlet which means sensors will be on whenever DJ is running/acc. Quote Link to comment Share on other sites More sharing options...
webslave Posted March 20, 2013 Report Share Posted March 20, 2013 Not only have I not been able to find a "freebie", I can't even get one off the Tech Authority website...I paid several hundred dollars (gladly) for the set I had on my '08 Jeep Commander, but, now they won't let you have one at any price...still haven't been able to buy one for my '11 RAM 2500 LongHorn HO CTD, either. I think that is totally wrong for any auto manufacturer to block repair manuals from the users. I realize that the cost of printing them is high, but, they won't even release the electronic versions. That's just wrong, in my book and may figure into a future vehicle purchase; I'm not likely to rebuild the engine, but, for something as simple as pulling trim to look for a short or to install an option not provided by the manufacturer (CB radio, for instance), you've got to have access to the proper procedure to keep from breaking something else and to be able to access torque values for simple repairs...for instance, what is the proper torque value for the caliper bolts when installing new pads? What is the proper procedure for getting the caliper pistons to retract? Raw deal...and if you do find one, let us know where you got it! byerleja 1 Quote Link to comment Share on other sites More sharing options...
Lebowski Posted March 20, 2013 Report Share Posted March 20, 2013 Not exactly what you're looking for but it could be useful This is the manual that explains how to install the backup camera, you can use the section regarding the side panel (which in turn requires removing the seats in the third row) and ignore the rest. Beware, it's not 100% accurate. Quote Link to comment Share on other sites More sharing options...
jojogg Posted March 25, 2013 Author Report Share Posted March 25, 2013 Thank you Lebowski, Looks like it is not so easy to install the parking sensor. I will try it to connect the sensor to the 12 vdc outlet. The pro is the sensor can detect if there is a car beside or not when try to change the lane. Thank you again. Not exactly what you're looking for but it could be usefulThis is the manual that explains how to install the backup camera, you can use the section regarding the side panel (which in turn requires removing the seats in the third row) and ignore the rest.Beware, it's not 100% accurate. Quote Link to comment Share on other sites More sharing options...
Lebowski Posted March 25, 2013 Report Share Posted March 25, 2013 These are the instruction for the installation of the OEM sensors (instructions for the journey starting at page 102). Again, take them with a grain of salt, but it seems there's no need to remove the panel since they take power from the brake light. Quote Link to comment Share on other sites More sharing options...
jojogg Posted March 25, 2013 Author Report Share Posted March 25, 2013 Thank you valuable information. BTW, do you know where can download the instruction for install roof rack for Dodge Journey? Thank you. These are the instruction for the installation of the OEM sensors (instructions for the journey starting at page 102).Again, take them with a grain of salt, but it seems there's no need to remove the panel since they take power from the brake light. Quote Link to comment Share on other sites More sharing options...
Lebowski Posted March 25, 2013 Report Share Posted March 25, 2013 (edited) You can try the same site: http://www.mopar-accessories.com Edited March 25, 2013 by Lebowski Quote Link to comment Share on other sites More sharing options...
jojogg Posted March 26, 2013 Author Report Share Posted March 26, 2013 Thank you. I checked the instruction of the OEM sensor and looks like it is not difficulty to install. However I found that the instruction shows should remove the ground power cord from the battery. Do you know what the reason and if the car will need reset computer system or not? What about to solder the power cable to rear parking power cable without disconnect the battery? Thank you again. You can try the same site:http://www.mopar-accessories.com Quote Link to comment Share on other sites More sharing options...
bigtsr Posted March 26, 2013 Report Share Posted March 26, 2013 NEVER perform electrical work on modern vehicles without diconnecting the battery. They have so many computer(s) linked in the electrical system that one short can do more harm than it's worth to save a few minutte. Journey_SeXT 1 Quote Link to comment Share on other sites More sharing options...
jojogg Posted March 26, 2013 Author Report Share Posted March 26, 2013 Will reset the computer system or not if disconnecting the ground power cord from the battery? Thank you. NEVER perform electrical work on modern vehicles withoutdiconnecting the battery. They have so many computer(s) linked in the electrical system that one short can do more harm than it's worth to save a few minutte. Quote Link to comment Share on other sites More sharing options...
bigtsr Posted March 26, 2013 Report Share Posted March 26, 2013 Disconnecting the battery will(after residual system charge disapates) will reset the TIPM (totally integrated power module) and reboot the CanBus computer. Quote Link to comment Share on other sites More sharing options...
jojogg Posted March 29, 2013 Author Report Share Posted March 29, 2013 (edited) is anyone know which pair is for reverse parking light? I found there are 3 group wires. And how to disconnect the connectors? Should I just pull them out or I need some special tools? Thank you. Edited April 14, 2013 by jojogg Quote Link to comment Share on other sites More sharing options...
jojogg Posted April 14, 2013 Author Report Share Posted April 14, 2013 I successfully installed the parking sensor. I followed the instruction for OEM parking sensor which Lebowski offered. And looks like mostly are correct. I used different holes. The power wire is write and tan, the ground is black. I did not soldering the wire. I just twisted the sensor power wires to parking light wires and typed them firmly. Now everything is ok. Thank you for all your guys help. Quote Link to comment Share on other sites More sharing options...
zgfjxpxh Posted November 16, 2013 Report Share Posted November 16, 2013 Thank you for this article. That's all I can say. You most definitely have produced this blog into something special. You clearly know that which you are doing, you've covered countless bases.Thanks!Belstaff JacketsBelstaff Blazer WomenBelstaff MotorcycleKaren Millen OutletTory Burch Flats Quote Link to comment Share on other sites More sharing options...
