tmajoros Posted March 24, 2013 Report Share Posted March 24, 2013 My battery went dead, charged ti up now remote starter not wrking correctly. Start it with remote it runs for about 10sec then turns off and will not remote start again the horn beeps once and thats it. Any answers or how to reprogram if that is what it needs. Quote Link to comment Share on other sites More sharing options...
bigtsr Posted March 24, 2013 Report Share Posted March 24, 2013 I don't believe that a reprogram should be necessary under normal circumstances. How old is the car battery? Have you tried resetting the TIPM/system by disconnecting the car battery for 15-20 minutes? tmajoros 1 Quote Link to comment Share on other sites More sharing options...
webslave Posted March 24, 2013 Report Share Posted March 24, 2013 (edited) The cars are designed to "detect any abnormal running events" and to shut themselves off when using the remote start option. There is something flagging your system with a problem and the car is shutting itself off as a cautionary procedure. I had that happen with my Commander. My guess is that although your battery has been "recharged", the CANBus is still sensing a problem and is aborting the remote start process. You may recharge the battery to a condition that enables a start, but, low voltage, or abnormally high alternator draw (particularly since the battery is "cold challenged" due to temperature), is causing a "fault" on the CANBus...you'll probably, IMHO, need to replace the battery to completely rectify the situation... Edited March 24, 2013 by webslave tmajoros and OhareFred 2 Quote Link to comment Share on other sites More sharing options...
tmajoros Posted March 24, 2013 Author Report Share Posted March 24, 2013 thanks guys i think i know what the prblem is now threw your responses. Quote Link to comment Share on other sites More sharing options...
weasey31 Posted March 17, 2017 Report Share Posted March 17, 2017 have 2009 R/T with remote start- had the same issue with remote start turning on then off after 5 seconds. will not turn back on using the FOB buttons on repress. At the time, the battery was giving problems starting the vehicle in the mornings. changed the battery (original 2009) to a new one. the problem went away, however it did it a few days later. i learned that problem will still be present if the battery voltage goes low. I never bothered charging the new battery. just swapped it and drove. i had to throw trickle charger on battery to peak it. remote has worked every time. Quote Link to comment Share on other sites More sharing options...
checkstr Posted March 18, 2019 Report Share Posted March 18, 2019 Hi...I'm having a similar issue but it has nothing to do with the battery as it is sufficiently charged. When I start the car with the fob, the engine cranks and it starts...5-10 seconds later, it shuts off and on the dash it says that the remote start has been disabled. The only thing that I can think of, is that I have a CEL on...It's code P0128 which points me to a thermostat/coolant issue but wouldn't think this would interfere with the remote start. Quote Link to comment Share on other sites More sharing options...
larryl Posted March 18, 2019 Report Share Posted March 18, 2019 If you have a cel light on it will interfere with the remote start it is a built in safeguard to protect the drivetrain.. checkstr, OhareFred and 2late4u 3 Quote Link to comment Share on other sites More sharing options...
checkstr Posted March 18, 2019 Report Share Posted March 18, 2019 Thanks larryl. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted March 18, 2019 Report Share Posted March 18, 2019 (edited) Straight outa the manual: To Enter Remote Start Mode, Press and release the REMOTE START button on the RKE transmitter twice within five sec-onds. The vehicle doors will lock, the parking lights will flash and the horn will chirp twice (if programmed). Then, the engine will start and the vehicle will remain in the Remote Start mode for a 15-minute cycle. NOTE: • If an engine fault is present or fuel level is low, the vehicle will start and then shut down in 10 seconds Edited March 18, 2019 by jkeaton 2late4u 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted March 18, 2019 Report Share Posted March 18, 2019 On 3/18/2019 at 5:42 PM, jkeaton said: Straight outa the manual: To Enter Remote Start Mode, Press and release the REMOTE START button on the RKE transmitter twice within five sec-onds. The vehicle doors will lock, the parking lights will flash and the horn will chirp twice (if programmed). Then, the engine will start and the vehicle will remain in the Remote Start mode for a 15-minute cycle. NOTE: • If an engine fault is present or fuel level is low, the vehicle will start and then shut down in 10 seconds Expand read a manual....LOL jkeaton and OhareFred 2 Quote Link to comment Share on other sites More sharing options...
Daniel Anderson Posted November 13, 2024 Report Share Posted November 13, 2024 My vehicle has stopped for low fuel light. The MIL has been on for stuck thermostat. Both instances the Command start was aborted. (2015 D Journey Crossroad AWD ) with V-6 engine. Thanks for this answer too Quote Link to comment Share on other sites More sharing options...
diymirage Posted November 13, 2024 Report Share Posted November 13, 2024 Both of those would cancel the remote start, just the way it's written into the computer Fill the tank, fix the CEL and you should be good to go Quote Link to comment Share on other sites More sharing options...
larryl Posted November 13, 2024 Report Share Posted November 13, 2024 Clear the CEL if it's for a stuck open Tstat Quote Link to comment Share on other sites More sharing options...
