Hi I got a 2010 sxt with the face lift interior, my key fob's have both stopped locking or opening the car most of the time, it was a intermittent problem every now and again but it's got worse and now doesn't work about 60 percent of the time,
It's still under warranty but is there a way to reset the system to save a day at the steelers.
Thanks
Rich
First thought would be new battery in the fob!
Second thought would be to reset the TIPM
by disconecting the battery for 10-15 minutes
letting residual charge drain off the system.
If both fobs act exactly the same then it could
be the module for interface.
There have been reports also of it acting differenly
when in park or neutral which leads to a home position
switch on shifter.
and make sure you don't have an iPhone near the fob. My doors won't open if I'm carrying the fob and the phone in the same hand.
never had this happen when we had our 2010 ??
Hi done some more testing, if I park in different spots both at home and at work its fine. If I pull off my drive by a six ft it work fine too. Could my broad band be messing with the signal off the fob?
anything could be interfering with it i guess, if it works everywhere but not in one area then best not to park there :)... also check the batteries like other have said....
Have changed the batteries, first thing I did and nothing changed. Been off work a couple of days and its been fine and come to think of it, it always plays up at home after its played up at work,
Something must be interfering while at work, phone mast, taxi company radio. I think it's just trial and error with my parking space I suppose.
