saskaman Posted April 19, 2013 Report Share Posted April 19, 2013 What oil are you using in your V6 Journey 5W20 or 5W30. Owners manual says to use 5W20 but I just had an oil change done at the dealership and they put in 5W30. Do you think I should get them to drop the new oil and change it to 5W20. This is my first oil change and first experience with service at this dealership. I feel they should have at least explained why they were using 5W30. Not impressed. Quote Link to comment Share on other sites More sharing options...
larryl Posted April 19, 2013 Report Share Posted April 19, 2013 yikes Quote Link to comment Share on other sites More sharing options...
bigtsr Posted April 19, 2013 Report Share Posted April 19, 2013 I use the recommended oil and I think they owe you an explanation. Quote Link to comment Share on other sites More sharing options...
Journey_SeXT Posted April 19, 2013 Report Share Posted April 19, 2013 On 4/19/2013 at 12:33 AM, saskaman said: What oil are you using in your V6 Journey 5W20 or 5W30. Owners manual says to use 5W20 but I just had an oil change done at the dealership and they put in 5W30. Do you think I should get them to drop the new oil and change it to 5W20. This is my first oil change and first experience with service at this dealership. I feel they should have at least explained why they were using 5W30. Not impressed. This is the reason why I prefer to do my own oil changes. The dealer was sloppy thinking the 2013's are like the previous model years using 5W30. I would have them change it to the recommended oil. Quote Link to comment Share on other sites More sharing options...
webslave Posted April 19, 2013 Report Share Posted April 19, 2013 It won't hurt your engine to have 5W-30 as opposed to 5W-20 in it. In fact, for summer use, it is better to have the added thickness of 30 at the "heated" end of the spectrum. As long as you have the cold start lubricity of the 5W, I only see poor public relations as opposed to a threat of your engine's life. Most auto makers have gone to thinner oils for economy's sake and not any specific need of the engine. The only exception is the Hemi with the MDS option; it needs 0W-20 in order for the valves to properly float when the MDS shuts off 4 cylinders. From the owner's manual (emphasis added): "SAE 5W-20 engine oil is recommended for all operating temperatures. This engine oil improves low temperature starting and vehicle fuel economy." Again, poor choice by the dealership in not informing you of the mistake and giving you the option of a drain/re-fill, but, there won't be any damage done to your Journey. Journey_SeXT 1 Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCACares Posted April 23, 2013 Official Dodge Support Report Share Posted April 23, 2013 On 4/19/2013 at 12:33 AM, saskaman said: What oil are you using in your V6 Journey 5W20 or 5W30. Owners manual says to use 5W20 but I just had an oil change done at the dealership and they put in 5W30. Do you think I should get them to drop the new oil and change it to 5W20. This is my first oil change and first experience with service at this dealership. I feel they should have at least explained why they were using 5W30. Not impressed. saskaman, Owner's manual is right, your Journey with the 3.6L uses 5W20 grade oil. It becomes your call if you want the dealer to replace the oil that was added. Speak with the Service Manager at your dealer as to why they used the 5W-30. Based off your location/climate they may have opted to use the 30, however again Chrysler recommends 5W-20 for your vehicle. Quote Link to comment Share on other sites More sharing options...
