Front Passenger One-Touch Power Window Operation
Hello there,
I have noticed on our 2013 Journey that the One-Touch Front Passenger Window does not operate properly.
When the window is all the way down and is operated to close using the One-Touch feature, it seems to stop 3/4 of the way up and then goes back down to 1/8.
Not sure if it is sensing an obstruction but it has been repetitive and the only solution is to hold the button for it to fully close.
Any feedback on this issue is much appreciated.
Thanks
There is a procedure to program window operation as I have
seen it posted somewhere.
If I remember correctly-you put window all the way down
holding button then all the way up again holding the up
button for a count of 6 seconds before releasing.
I wish I could reprog my memory!!!!!
  • Official Dodge Support
Hello there,
Thanks
Before you take it back to the dealership try re-setting it by using the procedure below.
Reset
It may be necessary at some point in time to reactivate the
Auto Up feature. To do so, perform the following procedure:
1. Pull the window switch up to close the window
completely and continue to hold the switch up for an
additional two seconds after the window is closed.
2. Push the window switch down firmly to the second
detent to open the window completely and continue
to hold the switch down for an additional two seconds
after the window is fully open.
Reset
That seems to have done the trick! Thank you!
Appreciate the help everyone.
13DODGE,
For future reference I feel my counterpart located this information from page 42 of your 2013 DJ Owner's Manual (First Edition). Never know when it may come in handy again!
((If you don't have the hard-copy, send my a PM)).
