IamtheDave Posted May 8, 2013 Report Share Posted May 8, 2013 Greetings! I am looking for any tips or tricks on removing the driver and passenger front seats. Like most, they simply unbolt but some have hairy connections that you can't just disconnect. Thank you in advance! Quote Link to comment Share on other sites More sharing options...
onecrazyfoo4u Posted May 8, 2013 Report Share Posted May 8, 2013 Just curious, why are you removing them? Quote Link to comment Share on other sites More sharing options...
IamtheDave Posted May 8, 2013 Author Report Share Posted May 8, 2013 Going to install a basic audio system. One 4 channel amplifier to run the doors and a self powered woofer in the back. I think installing the amp under the seat is going to be the best route. Quote Link to comment Share on other sites More sharing options...
bigtsr Posted May 8, 2013 Report Share Posted May 8, 2013 DISCONNECT the DJs battery as the seats/active head supports are linked to airbag system. Better safe than sorry! Quote Link to comment Share on other sites More sharing options...
nerner Posted May 9, 2013 Report Share Posted May 9, 2013 I installed my amp under the driver seat without having to remove the seat. Just removed those lower trim pieces by the door sills to run my wires and insert them under the carpet. Quote Link to comment Share on other sites More sharing options...
IamtheDave Posted May 9, 2013 Author Report Share Posted May 9, 2013 Nerner, How did you secure the amplifier? I was going to take a piece of wood, carpet it to match the factor color and screw it down. Then mount the amp to the board... I guess I could slide the amp in under the seat without removing it however I wouldn't know how to hold it down. Quote Link to comment Share on other sites More sharing options...
nerner Posted May 11, 2013 Report Share Posted May 11, 2013 On 5/9/2013 at 5:56 PM, IamtheDave said: Nerner, How did you secure the amplifier? I was going to take a piece of wood, carpet it to match the factor color and screw it down. Then mount the amp to the board... I guess I could slide the amp in under the seat without removing it however I wouldn't know how to hold it down. I slid a block of wood under the carpet, about 1/2" thick then then I bolted the amp onto it. Quote Link to comment Share on other sites More sharing options...
