haroldak47 Posted May 13, 2013 Report Share Posted May 13, 2013 Does anymore know the steps on how to open the passenger's door panel? My 2013 RT has been producing this rattling noise when driving over bumps. Seems to be at the speaker area. Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted May 13, 2013 Official Dodge Support Report Share Posted May 13, 2013 Does anymore know the steps on how to open the passenger's door panel? My 2013 RT has been producing this rattling noise when driving over bumps. Seems to be at the speaker area. Since the vehicle appears to still be under factory warranty I would urge you to have the dealership take a look. Having said that, instruction below. Remove fastener located in pull handle. Remove fastener near inside door handle. Using trim stick C-4755 or equivalent, gently pry upward on door trim panel disengaging trim panel from door run. Disconnect the power window switch if equipped. Remove trim panel from door assembly. Quote Link to comment Share on other sites More sharing options...
alpadilla73 Posted April 4, 2019 Report Share Posted April 4, 2019 Does anyone have instructions to remove the inner panel on the door that holds the motor? I need to remove the passenger door lock actuator. Quote Link to comment Share on other sites More sharing options...
