Towing with my 2012
marklee981
So im just wanting to make sure since my dealership could not give me a solid answer to this...
When I had my previous vehicle (2005 Chevy Equinox AWD) I was instructed that I needed to pull my boat in 4H so that the car would not shift into overdrive. However with the Journey there is nothing in the manual that states if I should use D or if I should use the Autostick for shifting.
What is recommended....I would like to make sure that if I can pull my trailer at highway speeds that I can use D and not have to stick with the autostick
  • Official Dodge Support
Automatic Transmission
The DRIVE range can be selected when towing. However,
if frequent shifting occurs while in this range, use
the Autostick feature to select a lower gear.
NOTE: Using a lower gear range while operating the
vehicle under heavy operating conditions will improve
performance and extend transmission life by reducing
excessive shifting and heat build up. This action will also
provide better engine braking.
If you REGULARLY tow a trailer for more than 45 minutes
of continuous operation, then change the transmission
fluid and automatic transmission filter according to
the interval specified for “police, taxi, fleet, or frequent
trailer towing.” Refer to the “Maintenance Schedule” for
the proper maintenance intervals.
I also tow a trailer close to the max towing weight and when I travel out on the highway. Most of the time, the transmission shift perfect but sometimes hunts annoyingly in hills or on windy days, I use the autostick to lock it down unto 5th gear and it's perfect. When I see a hill approaching, I put it back into Drive to make sure the transmission selects the right gear going uphill.
