How do I find out my bolt pattern and offset?
hereticj
I currently have 235/55/19 Michelins on. I would like to upgrade to a new set of rims to go with these tires.
I keep getting different numbers for the bolt pattern, depending on which site and calculator I use.
Is there anywhere I can get a definitive number on what I should be shopping for?
Thanks
Yes it is 5x5 or 5x127 both the same just standard and metric size . Look under jeeps ,Grand Cherokee they have same pattern . Just watch width I think max width for Journey is 8.5 inch .
Edited by Bubba
Correct:
5 Lug by 5in. or 127mm bolt spacing. (Both of these measurements 5x5" or 5x127 are the same thing.)
+45mm offset (Try to keep the offset of wheels purchased between +35mm and +55mm for the Journey.)
73.1mm Hub Bore (Important for wheel centre bore to be a match or larger. Larger hub bore wheels should have hub centring rings installed.)
  • 5 months later...
I was looking for this information today and found this old thread.
I just thought I would update it with the correct information for anyone else who may also be looking for this info.
The bolt pattern is indeed 5 x 127mm (or 5 x 5")
The offset on my 19" wheels are +40. The extra 5mm is probably to clear the brakes.
The centre bore is 71.5mm.
