JordynSXTAWD Posted June 29, 2013 Report Share Posted June 29, 2013 Hi. I am interested in getting a suspension/lift kit for my 2010 SXT AWD. Is it possible to do this with the AWD system on the Journey, or could it cause malfunctions in the censors??? Also What types of hazards could it cause? Worsen gas milleage?? Etc. Also if someone has done this, can i please have some pictures? I have looked all over trying to find pictures of lifted dodge journey's. Also where could i go to find such products to modify my Journey? Please help!! Thanks Link to comment Share on other sites More sharing options...
webslave Posted June 30, 2013 Report Share Posted June 30, 2013 (edited) Don't imagine anyone has lifted a DJ AWD. AWD is not 4x4 and lifting the DJ wouldn't achieve any "functional" use, it already has all the ground clearance, IMHO, that an AWD vehicle needs (more than some AWDs out there). That is probably why you'll be hard put to find a "kit" for raising the DJ...no demand. As for getting a one-off done at a specialty shop, I suspect you'll find that the U-joints will give out fairly quickly with more than a 2" lift and a 2" lift will be prohibitively expensive, again IMHO, for what you'd be getting. I'll even go out on a limb and predict that any lift, over stock, will give the axles a fit since the car is CUV and engineered as a CUV and does not have the heavier duty 4x4 equipment (joints, bearings, torsional strength, etc.) that those type of vehicles have. The DJ is a cross-over vehicle, not an off-road vehicle and the engineering isn't there to make it one. You can lift for the "look", but, I think mechanically you'd be making a mistake. Just my take... Edited June 30, 2013 by webslave OhareFred 1 Link to comment Share on other sites More sharing options...
bigtsr Posted June 30, 2013 Report Share Posted June 30, 2013 I agree with Webslave on the subject I think in the long run it could turn out to be expensive frustrating experience. Would have-should have bought a Jeep! OhareFred 1 Link to comment Share on other sites More sharing options...
Slick26 Posted August 7, 2013 Report Share Posted August 7, 2013 I've done some research on this as well, and haven't come up with much. It isn't that it isn't possible, it's just that it isn't practical. There isn't ANY demand whatsoever, so there are no kits available. And if you take it to a shop to have a custom lift kit put together, you're going to spend thousands of dollars for a 2" lift that really doesn't achieve anything. I've been on other forums and seen some very unique lifted vehicles. One of them being a Jeep Compass lifted 4". It looked wicked. The Compass is built on the Dodge Caliber platform, which is originally FWD-based, but available in AWD as well. If it's possible for the Caliber platform to be lifted, I'm positive it's possible for the Journey platform. This is my own opinion, but I think the Journey is too low from the factory. I was parked next to a Ford Escape that sat higher than my Journey. My mother's FWD Toyota RAV4 sits higher than my Journey. Just about every other CUV in the segment sits higher than the Journey. They easily could have lifted it another 1"-2" from the factory without affecting any AWD components. And it would be nice if they offered a more rugged trim level, but I don't see them doing that with other options in the line up. Link to comment Share on other sites More sharing options...
redtomatoman Posted August 7, 2013 Report Share Posted August 7, 2013 On 8/7/2013 at 5:23 AM, Slick26 said: This is my own opinion, but I think the Journey is too low from the factory. I was parked next to a Ford Escape that sat higher than my Journey. My mother's FWD Toyota RAV4 sits higher than my Journey. Just about every other CUV in the segment sits higher than the Journey. They easily could have lifted it another 1"-2" from the factory without affecting any AWD components. And it would be nice if they offered a more rugged trim level, but I don't see them doing that with other options in the line up. I'm not sure about other vehicles sitting higher. You may be right, but the DJ has nearly 8" of clearance. Pretty good for a "car". The question as to why Dodge would not lift the DJ further from the factory has a simple answer. On the same lot where the DJ is sold is a whole fleet of Jeep vehicles, all of which are intended, at least partially, for varying levels of off road use. There is no reason to equip the DJ for off road use. The aim of Dodge recently is to get back to its muscle/performance roots. While the Pentastar is no Hemi, it does give the DJ some muscle. Dodge is leaving the off-roading to Jeep and the top luxury for Chrysler. Peace. 2014jrt and OhareFred 1 1 Link to comment Share on other sites More sharing options...
bigtsr Posted August 7, 2013 Report Share Posted August 7, 2013 Don't forget the DJ is built on the Avenger platform which again is not an offroad rated vehicle. As pointed out that's what sells Jeeps. Link to comment Share on other sites More sharing options...
Shannon Kasprzyk Posted March 29, 2014 Report Share Posted March 29, 2014 Just recently seen a DJ lifted. Was in discount tire and he lifted it do to him wanting larger and wider tires. Dont know the exact lift in inches but it looked pretty good. Link to comment Share on other sites More sharing options...
jkeaton Posted March 29, 2014 Report Share Posted March 29, 2014 On 3/29/2014 at 9:08 AM, Shannon Kasprzyk said: Just recently seen a DJ lifted. Was in discount tire and he lifted it do to him wanting larger and wider tires. Dont know the exact lift in inches but it looked pretty good. As stated, it's not impossible, just impractical. Welcome to the forum Shannon! Link to comment Share on other sites More sharing options...
Mauldin Posted March 24, 2015 Report Share Posted March 24, 2015 You may be able to use 1" spacers between your struts and frame/body to do a lift. Import SUVs are know to use these to add larger tires. Link to comment Share on other sites More sharing options...
jkeaton Posted March 25, 2015 Report Share Posted March 25, 2015 Just realize you will void any warranty you may have. If your out of warranty, why not try? Or if you are still under warranty, don't go crying to the dealer when your CV axles explode. Link to comment Share on other sites More sharing options...
Lobitz68 Posted March 25, 2015 Report Share Posted March 25, 2015 (edited) On 3/25/2015 at 2:58 AM, 11journeybama said: Expand Same thing applies here... Edited November 20, 2017 by jkeaton Link to comment Share on other sites More sharing options...
silenze Posted March 26, 2015 Report Share Posted March 26, 2015 The journey is not a truck or suv. Its a cuv. A car with extra ground clearance Link to comment Share on other sites More sharing options...
Lobitz68 Posted March 26, 2015 Report Share Posted March 26, 2015 I thought Superman lived in the city? Link to comment Share on other sites More sharing options...
Lobitz68 Posted March 26, 2015 Report Share Posted March 26, 2015 On 3/26/2015 at 2:01 AM, silenze said: The journey is not a truck or suv. Its a cuv. A car with extra ground clearance Yep. And??? jkeaton 1 Link to comment Share on other sites More sharing options...
Dodee Posted November 20, 2017 Report Share Posted November 20, 2017 Were you able to install a suspension lift kit? any updates on what you did on your Journey? Link to comment Share on other sites More sharing options...
jkeaton Posted November 20, 2017 Report Share Posted November 20, 2017 On 11/20/2017 at 3:58 AM, Dodee said: Were you able to install a suspension lift kit? any updates on what you did on your Journey? Expand This thread is 4 years old. The OP is no longer an active member. Link to comment Share on other sites More sharing options...
