1st issue
larryl
I have developed a terrible bang in the right front strut or strut mount going through bumps that extend the strut then compress it not when it is compressed then normal
Well they are ordering a Strut -Strut Bearing & Plate & Stabilizer Link to see if will cure the bang
This I believe could be a serious issue with ALL Journeys
My BANG noise was caused by the Strut Bearing being PUNCTURED by the Strut Spring & the Spring becoming jammed inside the Bearing close to actual Strut
The reason for this is that the Strut Bearing assembly is made completely of PLASTIC!!!!!! No metal at all in the assembly not even a bushing
I'm going to contact Chrysler as is my dealer & the mechanic also told the parts person to order a bunch of them as they are going to be a problem
As a side note my left front spring is already starting to shift so next week they are going to install a new one on that side
I have taken pictures but cant seem to get them to upload but I can send them to an email if you wish to view them
Larry
  • 2 months later...
  • 8 months later...
