275/45/19 ??
rocky
I don't think you could safely mount a tire that's 2" wider then the originals on the same wheels (The shop may refuse to mount them). That would give you almost 4" of tire width overhang, much bigger than the 7" wide wheel.
I would go with 245/50 or 255/50 if you're looking for a wider tire that will safely fit on the wheel and not rub.
i am due for some new tires, looked arround found out that 275/45/19 will fit my 225/55/19 without speed adjustment... do you think it will rub ?
I agree with another poster, I not only think it will rub, it will look pretty funny. I realize your want of a larger tire but I truly think you should look at larger rims if you want to use those tires........Just my thoughts......
Terry
