Vehicle Tent/DJ Question
Does anyone use a vehicle tent with their DJ? Which one? How's the fit. Any paint damage? Anything that I should know? I am thinking about getting one but I'm not sure if there is any real advantage over my regular camping tent. Just wondering what other's experience is. Also, my main question is how the DJ will do with the rear gate door open all night or for extended periods of time. Will this wear on the battery? I know our DJs wake up whenever a door is opened or anything is changed in any way. TIA.
Peace.
You can disable the interior lights altogether by rotating the rheostat on the dash all the way down. This way, the lights don't wake up if you open a door. From the owner's manual:
Dimmer Control
The dimmer control is part of the headlight switch and is
located on the left side of the instrument panel. Rotating th
dimmer control upward with the parking lights or headlights
on will increase the brightness of the instrument panel
lights, door map pockets and cupholders (if equipped).
Dome Light Position
Rotate the left dimmer control completely upward to the
second detent to turn on the interior lights. The interior
lights will remain on when the dimmer control is in this
position.
Interior Light Defeat (OFF)
Rotate the dimmer control to the extreme bottom off
position. The interior lights will remain off when the
doors are open.
Parade Mode (Daytime Brightness Feature)
Rotate the dimmer control upward to the first detent.
This feature brightens all text displays such as the
odometer, EVIC (if equipped), and radio when the parking
lights or headlights are on.
Dimmer Controls
226 UNDERSTANDING THE FEATURES OF YOUR VEHICLE
