22" Viper Replica rims
King415
I have the Factory Reproduction 20 inch Viper rims + 35mm offset on my 2010 Journey , back fit fine front had to do some clearance work on front brake caliper . Ground a little off pad support rail on front calipers, mostly just the casting lines on it. Or you could use 1/8 inch spacer . Not sure about the 22 inch rims , they should be all right .
