Journeh Posted August 30, 2013 Report Share Posted August 30, 2013 I purchased a Curt hitch and wiring harness(for LED rear lights)...plugged it all in as per the instructions and my trailer lights worked. I didn't need to use that plug at the rear(it must be for the Dodge harness?). I'm thinking that you only need to flash the computer if you are using the Dodge harness. To install, take off the rear lights and plug the Curt connectors in...simple! I did need to run a power wire to the battery with the Curt harness. Quote Link to comment Share on other sites More sharing options...
boking1965 Posted November 18, 2013 Report Share Posted November 18, 2013 (edited) Yup did the same to mine from curt, hitch and wiring harness. Took a couple of hours and works great. My wifes 2013 has the towing package install and the two things I had to buy was the receiver and dodge's wiring harness. Have not installed it yet but soon. The instructions are very easy. Brett Edited November 18, 2013 by boking1965 Quote Link to comment Share on other sites More sharing options...
