09 dirty seats
PatriciaS
Someone mentioned on here how do you clean the light interior seats of an 09 DJ??? Well I found out!!!
You use the foaming window cleaner in a can. Spray it directly on the seat and let it sit for about a minute, and then use a wet cloth to rub it in, and Walah it's clean. I tryed it a few months ago, and that's all I use now and my seats look so nice and clean....
I believe this is the glass cleaner being referred to:
http://www.spraywayinc.com/content/glass-cleaner
And she's right, it is an amazing cleaner that I've used on glass and stainless. I've also used it occasionally on plastics and upholstry when I really need to clean stubborn dirt. But onecrazy is also correct in that it does contain alcohol. And even "perfume grade alcohol", whatever that is, will probably not be good over the long term. The same company also makes a product made for the purpose that would be a better bet:
http://www.spraywayinc.com/content/vinyl-leather-cleaner
  • 1 year later...
Be cautious and test a small out-of-sight section first. If the seats are cloth (I'm assuming they are since no one has mentioned proper leather cleaners), there is a chance the foam under the cloth could become wet and bleed into the cloth.
I haven't had to clean cloth seats in probably 7 years, but I would start with using a shop vac to clean the seats, spray a dry foam on the stained area, let it dwell a few minutes, scrub it with a brush, wipe away with MF towel, and shop-vac it again. May take a few hits if the stains are old/bad.
I clean my leather using that method and leather cleaners. Vac, spray cleaner, brush it on (I use a soft-bristle tooth brush), wipe away with towel, apply conditioner (not needed for cloth).
  • 10 months later...
