Android - Torque Pro - who uses???
Rubberdude88
Hey all. I use an Android app on my S3 called Torque Pro. It is an app that runs with a Bluetooth adapter (available off eBay for $30) and provides over 100 points of ECU data from speed & rpm's to intake air temp & 0 to 60 time. It can also read codes and clear codes. You can take video with multiple parameter gauges imposed on the screen.
Just wondering if anyone else uses this. I will post a 0 to 60 video in the next couple of days. So far, a 7.6 is what I have run - direct from the OBD - not GPS speed.
Anyway, great little app to have - if your a "data" person.
  • 1 year later...
I have an ELM 327 Mini BT adapter that works with my '14 R/T Rallye AWD. Sadly it does not work with my '02 300M Special, which is the car I intended it for (I have a Nexus 7 installed in place of the radio with Torque Pro installed). I'll be looking for a different adapter in the future after I've created another bezel for that car. Not a priority at the moment.
