FROGBOX Posted June 25, 2014 Author Report Share Posted June 25, 2014 Thanks again Frogbox. You wouldn't happen to know the part numbers needed to do the rear big brake upgrade? The parts for the rear upgrade is listed in post #30 in this thread. However, I do not suggest spending the $$$ on upgrading the rears to new parts. If you can't find the parts used, wait till you can. There will be more 2013's & 14's in the wrecking yards in the next few years. You can get everything from a wrecked Journey for around $150 and do the swap later. Quote Link to comment Share on other sites More sharing options...
cwczx3 Posted July 15, 2014 Report Share Posted July 15, 2014 FrogBox I ordered everything off of you parts list for the fronts and the part# for the front pads is the older smaller pads. Old pads are code BRF Part# 68093323AB New pads are code BRE Part# 68144163AE Other than that everything else looks to be correct. Quote Link to comment Share on other sites More sharing options...
cwczx3 Posted July 16, 2014 Report Share Posted July 16, 2014 (edited) Here is the part number listed Which is the same smaller pads This is what i ended up using for pads. Edited July 16, 2014 by cwczx3 Quote Link to comment Share on other sites More sharing options...
FROGBOX Posted August 6, 2014 Author Report Share Posted August 6, 2014 (edited) FrogBox I ordered everything off of you parts list for the fronts and the part# for the front pads is the older smaller pads. Old pads are code BRF Part# 68093323AB New pads are code BRE Part# 68144163AE Other than that everything else looks to be correct. My apologies and thanks for letting us know. I had so many screens open from different parts web sites I must have copied the wrong one. The original post has been edited with the correct part numbers. Thanks again. One note, the BRE part number I found is 68159579AC, which is different from yours??? Edited August 6, 2014 by FROGBOX Quote Link to comment Share on other sites More sharing options...
Easy Posted August 17, 2014 Report Share Posted August 17, 2014 Ever since Frogbox started this topic, I've been thinking of doing this and - low and behold - today I did it! And since I have't seen a Canadian price list yet, I thought I'd post one for my fellow citizens: Caliper (L) 68144161AA 1 $167.00 (includes $20 core charge) Caliper ® 68144160AA 1 $167.00 (includes $20 core charge) Carrier (bracket) 68159578AA 2 $51.75/ea Dust shield (L) 04779907AA 1 $7.80 Dust shield ® 04779906AA 1 $7.80 Pin kit 68144165AA 2 $31.50/ea All the above prices are from a Chrysler dealer in Ontario. Pads and rotors exist from several manufacturers, OEM or after market. I chose Centric rotors @ $125/ea and Centric Posiquiet ceramic pads @ $89.95/set. And just to add to the long list of people who recognized the quality of the original post, please let me say once again: Frogbox, you rock! Quote Link to comment Share on other sites More sharing options...
FROGBOX Posted August 17, 2014 Author Report Share Posted August 17, 2014 (edited) Ouch. You paid dealership prices for the parts? If you haven't installed the parts yet, and the dealership will take the calipers & brackets back, there are much cheaper options. First option is used calipers & brackets. Go to www.car-part.com Coreys Auto wrecker in London has a set of front calipers & brackets for $60 per side. So for $120 instead of $435, you are halfway there. Then go to www.rockauto.com to order the pads & rotors. The same ones you bought (Centric) are $70 each rotor & $40 for the pads. Shipping is quite expensive, but still cheaper than buying local. The dust sheilds & pin kit you might as well keep as they are not that expensive. The second option is all new/rebuilt parts from Rock Auto. Centric calipers are $127 each (which includes a $82 core charge) and they include the brackets. So $127 per side instead of $219 from the dealer. Edited August 17, 2014 by FROGBOX Easy and dhh3 2 Quote Link to comment Share on other sites More sharing options...
Easy Posted August 19, 2014 Report Share Posted August 19, 2014 "Ouch" is right :-) but I've already purchased and installed them. I have tried some scrap yards in the Greater Toronto Area and they won't sell used calipers (I guess for liability reasons). I've researched other sources too, on the web and even walked into places like NAPA Auto Parts and they were unable to cross-reference the calipers and brackets. Anyway, after all it's only money and the bottom line is I'm very happy with the way they perform, so no regrets... Oh, by the way, I need to mention something that was a first for me: the two slider-pins for the calipers are not identical; so for those who want to do this and they're not sure which goes where, the long one goes at the top and the small plastic sleeve that comes as part of the kit must be set on the small diameter recess at the end of the pin, prior to inserting it into the bracket. dhh3 1 Quote Link to comment Share on other sites More sharing options...
fox_raycing Posted October 18, 2014 Report Share Posted October 18, 2014 I finally made an account on here today. 1 year ago i got tired of my brakes and bought drilled and slotted rotors and ceramic pads for all 4 corners of my wifes dj. Well they lasted about 6 months and then around 7 on the warpage came back and now were at a year and i cant stand it any longer. I am getting them warrntied and they uograded to the bigger rotors for me at no charge. Rockauto.com seems to have decent prices on the calipers. 52 bucks for fronts with bracket and hardware. Now its another 45 for core and im not to fond to junk stock ones just in case. So i plan on going to junk yard and seeing what i can find. At least just send them back a random pair lol. But i just wanted to say im upgrading the back ones as well so ill definatley give an update when im done. It will still be a while seeings how i have to order the parts and i work a lot but ill keep you guys updated. Like everyone else i want to thank frogbox for doing this. Now i can be the guinnea pig for the rears lol. dhh3 1 Quote Link to comment Share on other sites More sharing options...
fox_raycing Posted October 18, 2014 Report Share Posted October 18, 2014 Also for who is interested. I used brakelabs.com dhh3 1 Quote Link to comment Share on other sites More sharing options...
SuperDave Posted October 18, 2014 Report Share Posted October 18, 2014 Great post frog box! I did my fronts a month ago and wanted to do the upgrade but I had trouble sourcing the parts used from the wrecker so in the end I just ended up replacing the fronts with aftermarket better quality parts. I regret not doing the upgrade though as brake performance isn't much better and I'll probably be faced with warped rotors again in 12 months or so..... Anyways I thought my brake problems were over for at least a while when this week I took a look at the rears and they're literally down to the metal! I have a 2011 R/T with 75k on it. I can't remember the last time I've replaced rear brakes on any vehicle. Poor design all around. I now have an interesting problem. I wound in the rear brake pistons and replaced the rotors and pads but I now have a soft brake pedal. I bled the brakes but it's still there. Really spongy and I can brake right to the floor. I'm thinking that when I wound the pistons back in the brake fluid pushing back up through the master cylinder may have damaged it somehow?? Has anyone experienced this?? Thx dhh3 1 Quote Link to comment Share on other sites More sharing options...
fox_raycing Posted October 18, 2014 Report Share Posted October 18, 2014 Ive expierenced something similar. And like you i had bled the brakes. I recomend having them pressure bled or vacuum bled. It solved my problem just when i thought something serious was wrong and hours of manually bleeding. Sorry to hear about your brakes. I to had biught upgraded oem parts with no luck. You need to just bite the bullet and do the real thing. Good luck dhh3 1 Quote Link to comment Share on other sites More sharing options...
SuperDave Posted October 18, 2014 Report Share Posted October 18, 2014 I took it into my local budget brake and muffler. It turned out to be the master cylinder. I guess it didn't like the fluid pushback. He also mentioned the problems he's seen with the journeys brakes. Definitely helping keep him in business! When I do the larger disc upgrade I will do all four at once dhh3 1 Quote Link to comment Share on other sites More sharing options...
fox_raycing Posted October 20, 2014 Report Share Posted October 20, 2014 OK...... Just wanted to throw this helpful website out there if anyone is interested in finding parts at a cheaper price.... www.car-part.com it seems to be worldwide just about... i just ordered all 4 corner calipers with hardware for $135 shipped to me. Now these are used parts from a salvage yard but the nice thing about it is they almost all ship so it doesnt really matter how far away you are also they are pretty much new anyway being 2013. I also did some more research.. The front calipers and rotors are the same as the caravans but the rear calipers are not interchangable. http://www.moparpartsoverstock.com this is the website i used to verify this information. Good luck to everyone. i can't wait to get this done. very excited. i actually look forward to work on my car. lol And to also go in trips in it again as well. dhh3 and SuperDave 2 Quote Link to comment Share on other sites More sharing options...
SuperDave Posted October 21, 2014 Report Share Posted October 21, 2014 Maybe a one off thing but when I turned back the rear calipers it also caused air to enter the abs system giving me a fault and the abs brakes would engage with medium braking. So I ended up bleeding that the abs system as well in the rear. The abs is electronic but tied into a vacuum line system which ended up producing the fault. If ur brakes are severely worn I would recommend opening the bleed port to relieve excess pressure before resetting the calipers. dhh3 1 Quote Link to comment Share on other sites More sharing options...
fox_raycing Posted February 22, 2015 Report Share Posted February 22, 2015 Hey guys.... I know this thread is a little old by now. but I just wanted to tell everyone that I didn't end up doing the big brake conversion on our journey as we ended up trading it in just a few weeks ago on a 2014 town and country. So with that said I have a COMPLETE big brake conversion for sale. Stock calipers off of a 2014 journey with brackets and hardware for all 4 corners and aftermarket drilled and slotted rotors with ceramic pads also for a 2014 journey. email me a fox_raycing@yahoo.com for more info. dhh3 1 Quote Link to comment Share on other sites More sharing options...
cplmadison Posted March 8, 2015 Report Share Posted March 8, 2015 damn and im in the UK lol Will these same parts go on my 2010 2.0 CRD SXT ? (I have stock 17" wheels) dhh3 1 Quote Link to comment Share on other sites More sharing options...
phi delt reefer Posted March 16, 2015 Report Share Posted March 16, 2015 just did my big brake conversion on '11 R/T. took about 4 hours only because I'm an idiot and didnt think things through but i did the entire job myself. I went through two sets of rotors up front and three in the back. for those who are looking to change the rears, dont. Instead get the latest caliper/pad adapter for that generation of brakes and swap it in (keeping the same caliper) - they have been re-designed and my rears haven't warped like the last two times. They just need a quick grind to remove some grooves. dhh3 1 Quote Link to comment Share on other sites More sharing options...
Dakota_Don Posted August 8, 2015 Report Share Posted August 8, 2015 Hello I have the 2010 journey.. I was doing this same thing before I seen your post.. I ordered new calipers/mounts rotors all new from rock auto.. it went together easy and well.. except I had a mushy pedal... no air in line.. since I have the 2010 I was wondering if anyone knows if the MC is different from the 2011/12 to the 2010... I don't have air in the system.. I since then reinstalled the OEM brakes .. nice firm pedal again.. thanks dhh3 1 Quote Link to comment Share on other sites More sharing options...
brwengel Posted September 13, 2015 Report Share Posted September 13, 2015 Hello I have the 2010 journey.. I was doing this same thing before I seen your post.. I ordered new calipers/mounts rotors all new from rock auto.. it went together easy and well.. except I had a mushy pedal... no air in line.. since I have the 2010 I was wondering if anyone knows if the MC is different from the 2011/12 to the 2010... I don't have air in the system.. I since then reinstalled the OEM brakes .. nice firm pedal again.. thanks I just did my upgrade on the front wheels of my '09 this past weekend. I got my calipers from a junkyard and put new factory rotors and new pads on. Bled the brakes until new fluid came out and I had great pedal immediately. Was a very easy upgrade and I worried about bleeding the anti-lock brakes for nothing...... jkeaton, dhh3, dj cowboy and 1 other 4 Quote Link to comment Share on other sites More sharing options...
sgs Posted September 17, 2015 Report Share Posted September 17, 2015 Very informative! Thanks for the info and details!! The Dodge Journey that the parts were taken off of, was it an SXT ? (or is the brake system the same across the spectrum)? Also, I'd like to match the rear brakes with the front. What would you recommend? Thanks! dhh3 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
bfurth Posted September 18, 2015 Report Share Posted September 18, 2015 The "big brakes" are the newer heavy duty brakes that are used on both the Journey and Grand Caravan/Town & Country platforms. For the model years which have them, they are standard across the entire trim line (at least starting in 2014). If you don't have 17" rims, you can't perform the upgrade (unless you go out and get the rims as well). Journey owners are not the only people doing this upgrade. jkeaton and dhh3 2 Quote Link to comment Share on other sites More sharing options...
bfurth Posted September 18, 2015 Report Share Posted September 18, 2015 The ABS system would only need to be bled if you were working on the ABS components directly. Or you were particularly slow in attaching the new caliper to the brake line and allowed the now-open circuit to drain the master cylinder completely. Then you'd have a bigger problem (bench bleeding the master cylinder as well as an ABS bleed). dhh3 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
fox_raycing Posted October 19, 2015 Report Share Posted October 19, 2015 Just to throw it out there I still have a COMPLETE BIG BRAKE SYSTEM for sale. Includes all 4 calipers, brand new ceramic brake pads with brand new drilled and slotted rotors. Pads and Rotors are from brake labs ( https://www.brakelabs.com/shopping_cart/productdetails/brake-kits-4-drilled-and-slotted-kit). This set sells for $385 I also have 2 Brand new in the box SPC rear adjustable control arms ( http://www.summitracing.com/parts/sps-67015 ). Im open for offers on everything. Shipping is probably the most difficult part but if your close by maybe we could meet half way. Im located in central california. you can email me at fox_raycing@yahoo.com dhh3 1 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted October 20, 2015 Report Share Posted October 20, 2015 Good deal. Wish I needed brakes. 1/2 way for me would probably Colorado! Quote Link to comment Share on other sites More sharing options...
Ski Valley Posted November 11, 2015 Report Share Posted November 11, 2015 Hi Frogbox, wish I had read your post 2 brake jobs ago. I was a parts manager at a very large Chrysler store and I was fanatical about comparing all of our rotors and pads to merge duplicate sizes thus reducing inventory. Our moto was chryler was not our friend. You have found a great solution to problem that dealers should be offering. None of my pad and rotor combos ever exceeded 150.00 bucks and we sold a ton of brakes. Most of my peers poo pooed this as to much work but they did not sell 12 milliom a year. Thanks again to a retired guy who is now treated like every other smuck. Quote Link to comment Share on other sites More sharing options...
