jkeaton Posted May 20, 2021 Report Share Posted May 20, 2021 On 5/20/2021 at 11:48 AM, sppmaster said: If anyone is able to pull it from here Internet archive here www.archive.org I've tried but I can see only a few pics. Can anyone try to pull the archived page. Maybe we still have a chance. Expand You can try. Quote Link to comment Share on other sites More sharing options...
sppmaster Posted May 20, 2021 Report Share Posted May 20, 2021 Maybe the Author of this thread can recover the pictures. Quote Link to comment Share on other sites More sharing options...
FROGBOX Posted May 20, 2021 Author Report Share Posted May 20, 2021 The pictures were hosted by fototime and they had a catastrophic event a few months ago. All photos were lost and they basically ceased operating. I lost over 1000 pictures. I had hundreds of how to posts like this one as a member of tdiclub. It will be a monumental task to try to find all the pictures in my backed up drives, but I will see what I can do. sppmaster 1 Quote Link to comment Share on other sites More sharing options...
sppmaster Posted May 20, 2021 Report Share Posted May 20, 2021 (edited) On 5/20/2021 at 12:53 PM, FROGBOX said: The pictures were hosted by fototime and they had a catastrophic event a few months ago. All photos were lost and they basically ceased operating. I lost over 1000 pictures. I had hundreds of how to posts like this one as a member of tdiclub. It will be a monumental task to try to find all the pictures in my backed up drives, but I will see what I can do. Expand You are really great. Maybe in this case it'll be easier for you to take a note of the date of your posts and search your backup for pictures taken around that dates. Edit: I've got 2 pictures from webarchive - there are dates on them. Edited May 20, 2021 by sppmaster Attached pictures Quote Link to comment Share on other sites More sharing options...
Shadow Rider Posted September 5, 2023 Report Share Posted September 5, 2023 (edited) Hey FROGBOX, I see you haven't been on for awhile but I will try to send you a question. Will this work with the 19" rims. Or if anyone else can answer. Martin Edited September 5, 2023 by Shadow Rider Open to more people Quote Link to comment Share on other sites More sharing options...
sppmaster Posted Wednesday at 09:46 PM Report Share Posted Wednesday at 09:46 PM (edited) I've just done the big brakes upgrade on all four wheels of my car. Thanks again for the perfect guide. The only issue that remains on my car is the low and spongy brake pedal. It seems like there is no solution to it. I've tried at least 10 other cars with the same low and spongy brake pedal and I'm really puzzled how often it can be seen and even more puzzled that the owners don't care for it. Here is the result. Edited Wednesday at 09:50 PM by sppmaster Quote Link to comment Share on other sites More sharing options...
John/Horace Posted Friday at 04:24 AM Report Share Posted Friday at 04:24 AM (edited) Soft pedal is fixable with hydraulic brake systems. The rear calipers on these cars with the integrated parking brake set up have a tendency to start to seize up if not constantly used, have experienced it. The return spring becomes not strong enough to fully release pads. You can tell by looking at parking brake mechanism if it’s starting to stick a bit. It also interferes with caliper function so brake bleeding difficult and soft pedal occurs. Either buy a rebuild kit with seals or buy another caliper. The second wheel down in your picture is not wearing evenly, it’s a rear wheel. I would start there. Small 4” piece of clear hose on bleeder screws helps see when air bubbles stop. Cross bleeder pattern front to back starting on passenger rear wheel. Don’t let master go low and allow air in to system. Or pay a mechanic with a vacuum bleeder unit. Edited Friday at 04:27 AM by John/Horace Quote Link to comment Share on other sites More sharing options...
5rebel9 Posted Friday at 11:06 AM Report Share Posted Friday at 11:06 AM I can't say my little "trick" with new/rebuilt REAR calipers will fix this type of problem, BUT.... What I do when installing such calipers is to apply /release the parking brake a couple of times BEFORE bleeding the caliper. This moves the piston manually{not hydraulically} from being "bottomed out in the caliper , allowing more fluid in. With 3 of these cars, I've not had this soft/low pedal situation show up yet and I've done brakes on all of them. I also do the same when just doing pads/rotors after retracting the pistons. Also watch out for stuck caliper slide pins, another common "quirk". John/Horace 1 Quote Link to comment Share on other sites More sharing options...
sppmaster Posted Friday at 10:34 PM Report Share Posted Friday at 10:34 PM Thanks both for your answers. The whole brake system (all calipers) was completely revised. All calipers move normally and the rotors and pads are completely new. I had the same soft and low brake pedal with the smaller brakes too. Actually it was perfect (no soft and low) but the dealer made a brake fluid change and then the pedal became soft and low. I use the parking brake every time I park the car. I'll try to perform brake air bleeding wit the diagnostic software. Quote Link to comment Share on other sites More sharing options...
