Panels and buttons
trevcda
I've got a 2010 R/T. I was wondering what was behind the panel where the rear AC controls would go if I had rear air. Is there sufficient depth to mount some indication LEDs? Is that panel easily replaceable to go back to stock when needed?
I'm also curious about the bank of switches above it that control heated seats, emergency flashers, AC and traction control. There are two blank spots where switches could be added. What options were designed to occupy those spots? Can I get these switches for adding my own accessories?
Does anyone have the part name and number for the panel/hood for the navigation radio at the top of the mid stack? I'm thinking of two things here. I'd like to install an aftermarket GPS in this location in a semi-permanent way so that it's hard wired, but would like to use the factory enclosure. The other thought would be to install factory GPS in that location while mainting the original REN radio below. Any thoughts on either scenario?
Had the damn thing less than two months and I'm already trying to do stuff to it!
Not sure what the 2010 stack looks like but in the 2012 models, the soft touch buttons are hazards, AC, AC flow, front defog, rear defog, traction control. I'm sure you can get the buttons from a wrecker or dealer and wire them up for your LED lighting or anything else.
Edited by Rubberdude88
Behind those panels, there's probably nothing.
Behind the empty switches, the same. You'd probably can't use the OEM switches to control anything. You'd need to know what lead does what, and the plugs aren't universal.
You know, you can get the factory my gig with nav to fit where your REN radio is already without loosing any functionality.
There's lots of empty space behind the dash, with a drill, a dremel and imagination, you can add any swtuch to anywhere on the dash.
