wburmil Posted October 25, 2013 Report Share Posted October 25, 2013 (edited) The passanger front seat with the plastic storage compartment makes a annoying squeek when some one sits there. Its so anoying as one drives you just hear the seat make this anoying sound. Has any one else had this issue and if so any fix ? I will go back to dealer soon for first oil change, Thanks Walter Edited October 25, 2013 by wburmil Quote Link to comment Share on other sites More sharing options...
2late4u Posted October 25, 2013 Report Share Posted October 25, 2013 no prob with mine going on 58k miles so far Quote Link to comment Share on other sites More sharing options...
webslave Posted October 25, 2013 Report Share Posted October 25, 2013 Not normal, at least mine doesn't make any noise. I'd have the dealer take a look at it. There are 4 little rubber feet to cushion the seat in the closed position on each side on the bottom of the seat portion (at least on '13 model), maybe one is missing allowing for plastic on plastic movement giving you the squeak. Mine snaps firmly shut and whether someone is sitting on it or not, there is no movement in the seat to cause any noises with the little rubber feet firmly holding the seat in place when latched... Quote Link to comment Share on other sites More sharing options...
rolly Posted October 25, 2013 Report Share Posted October 25, 2013 Mine is fine as well. Quote Link to comment Share on other sites More sharing options...
wingit11 Posted October 26, 2013 Report Share Posted October 26, 2013 No problem with mine. 12,000 km so far. Get dealer to look at it. Should not be an issue for you. Quote Link to comment Share on other sites More sharing options...
