Help Understanding Build Codes Please
Greetings,
I have the build sheet for my 2012 DJ Crew; I'm the second owner bought from the dealership where it was originally sold. There are some build codes I don't understand and am hoping the collective wisdom (or just one knowledgeable person) can help me. Here we go . . .
Vehicle Option - All
LBLS Driver Passenger Lower LED Lamps
- Are these the LEDs at the bottom of the door that shine on the ground?
LMKS Daytime Running Headlamps, High Beam
- Does this mean my DRLs are on with high beam?
LPSS CHMSL Lamp
- What is this?
SBPS Performance Steering
- Is this the stock steering?
SDDS Touring Suspension
- Assuming this is the stock suspension?
X81S Instrument Panel Parts Module
X82S Door Parts Module
X83S Front End Parts Module
X84S Front Suspension Parts Module
X85S Rear Suspension Parts Module
X88S Tire Wheel Parts Module
- What are all these "X8*S" modules?
- Where are X86S and X87S?
Z1AS GVW/Payload Rating
- What is this?
Optional Equipment
Tire Pressure Monitoring System -- I think these three codes are related to the TPMS
X88S Tire Wheel Parts Module: I think this contains (among other things) the Sensor/WiFi Transmitters?
CX8P CORA Tire Press Monitoring Sensor: I think this is the WiFi receiver?
XGMP Tire Pressure Monitoring Display: I think this is what presents data from the receiver to the EVIC display?
X9AP For More Info, Call 888-539-7474
- I think this is to activate Sirius?
ZBHP Spring - Left Front
ZCUP Spring - Left Rear
ZPFP Spring - Right Front
ZRUP Spring - Right Rear
- I'm assuming these are suspension related? Why would these show under Optional Equipment?
0CBA FAM: JC Tracking: [bunch of numbers] MY: 2012
- What on earth is this?
2DLA Customer Preferred Package 2DL
28L Customer Preferred Package 28L
- what are these?
If anyone can help me understand any of these codes I would be ecstatic!
Thanks,
Matthew
Edited by Isaiah6113
Another not knowledgeable person here.. May i know where you get that build codes. Is it included when you pirchase vehicle or yoiu have to request for it. Do i have to pay for it? i didnt get one.
Thank you!
If you PM DodgeCaresCa and provide your VIN# he can email you your build sheet. I got mine earlier this year and there was no charge.
You can also use this link. I filled it out and in less than an hour I had my build sheet.
http://www.dodge.com/webselfservice/dodge/emailpage.html?appStr=wccs&titleStr=Contact+Dodge&familyStr=brand&franchise=D&actionURL=%2Fwccs%2Fbrand_forms%2Fus%2Fwebform.jsp&promotion=null&category=U
In the area that says "Briefly describe" put "Vehicle Build Sheet". If you want to elaborate a little more as to why you want your build sheet, use the additional information area.
My build sheet. Apparently my car is a Hero??
According to our records, your vehicle was equipped from the factory
with the following:
VIN: XXXXXXXXXDT660851
Vehicle Description: DODGE JOURNEY HERO HATCHBACK
Model Year: 2013
Body Model: JC D E 49
Sales Code Description
E7 Prem Cloth Low-Back Bucket Seats
X9 Black
AFB Comfort/Convenience Group
AGV Flexible Seating Group
APAS Monotone Paint
BABS 160 Amp Alternator
BCPS 525 Amp Maintenance Free Battery
BGES Brake Assist
BNBS Electronic Stability Control
BNMP Traction Control
BNSP Electronic Roll Mitigation
BNTP Trailer Sway Damping
BRES Anti-Lock 4-Wheel-Disc Brakes
CACS Low Back Bucket Seats
CAUP 3rd Row 50/50 Fold/Reclining Seat
CBDS Active Head Restraints
CB9S 2nd Row In Floor Storage Bins
CDKP Easy Entry System Seat
CDWP Frt Pass Forward Fold Flat Seat
CFJS Rear Reclining / Fold Flat Seat
CGDS Front Height Adjust Shoulder Belts
CGUS Child Seat Anchor System-LATCH Ready
CGYS Drvr Inflatable Knee-Bolster Air Bag
CG3S Advanced Multistage Front Air Bags
CG4P 2nd Row 40/60 Tilt & Slide Seat
CJ1S Supplemental Frt Seat Side Air Bags
CJ5S Supp. Side Curtain All Rows Air Bags
CKCS Floor Carpet
CKRS Cargo Net
CKTS Cargo Tie Down Loops
CLES Front & Rear Floor Mats
CLPS Door Sill Scuff Pads
CS8P Delete Cargo Compartment Cover
CTLS Base Door Trim Panel
CVGP Passenger in Seat Cushion Storage
CVMS Full Length Flr Console Prem A/Rest
CWPS Illuminated Cupholders
DBAC All Automatic Transmissions
DG2 6-Speed Automatic 62TE Transmission
DHDP AutoStick ® Automatic Transmission
EAGC All Gas Engine
ERB 3.6L V6 24V VVT Engine
GAES Sunscreen Glass
GBBS Tinted Windshield Glass
GFAS Rear Window Defroster
GNAS Rear View Day/Night Mirror
GNFS Driver Side Sun Visor w/Mirror
GNYS Passenger Side Sun Visor
GTSS Power Heated Mirrors, Fold-Away
GXDS Remote Proximity Keyless Entry
GXRS Keyless Entry
GXXS Sentry Key Theft Deterrent System
GX4S Keyless Go
HAGP Air Conditioning w/3 Zone Temp Cntrl
HBBP Rear Air Conditioning w/Heater
JATS Premium Instr Cluster w/Display
JA2S Instrument Cluster w/Tach
JA6S Premium Instrument Cluster
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JHBS Rear Window Wiper/Washer
JJBS Dual Note Electric Horns
JKFS Cowl Mounted Hood Release
JKPS 12V Auxiliary Power Outlet
JKWS 12V Center Console Power Outlet
JMAS Air Filtering
JPBS Power Locks
JPDS Power Windows, Driver One-Touch
JPSP Power 6-Way Driver Seat
JPUP Power 4-Way Driver Lumbar Adjust
LAXS Front Passenger Seat Belt Alert
LAYS LED Tail Lamps
LAZS Vehicle Information Center
LBCS Glove Box Lamp
LBLS Driver & Passenger Lower LED Lamps
LCAS Front Courtesy/Map Lamps
LCES Rear Courtesy/Reading Lamps
LDFS Liftgate Flood Lamp
LEPP Body Color Exterior Mirrors
LHDS Headlamp Off Time Delay
LMES Halogen Quad Headlamps
LMK Daytime Running Headlamps, High Beam
LNJS Fog Lamps
LPSS CHMSL Lamp
LPTS Backup Lamps
MCZP Dodge Performance Body Color Fascias
MDAP Frt License Plate Attachment Screws
MFDS Bright Grille
MGDS SXT Badge
MGNS Dodge Badge
MHAS Black Windshield Moldings
MNKS Body Color Door Handles
MPFS Journey Badge
MPJS Black Sill
MPLS Black-Out Tape
MP2S Silver Mold In Color Fascia Applique
MW1S Black Side Roof Rails
MZ1P Flex Fuel Badge
NAS 50 State Emissions
NELP Dual Bright Exhaust Tips
NFPS 20.5 Gallon Fuel Tank
NHAP Engine Oil Cooler
NHJP Exterior Mirrors w/Heating Element
NHMS Speed Control
PR1 Bright Red Clear Coat
QR1S Bright Red Clear Coat
RCGS 6 Speakers
RDBS Removable Short Mast Antenna
RDZS Steering Wheel Mounted Audio Ctrls
REBS Uconnect 4.3S AM/FM/CD/MP3
RFKP 4.3" Touch Screen Display
RSCP SIRIUS Satellite Radio
RSUP Audio Jack Input for Mobile Devices
RSXP Remote USB Port
SCAS Steering Wheel
SDDP Touring Suspension
SUDS Tilt/Telescope Steering Column
TBKS Compact Spare Tire
TWBS P225/65R17 BSW A/S Touring Tires
TZLP Kumho Brand Tires
WFES 17X6.5 Aluminum Wheels
XBNP Tip Start
XHLS 12V DC Front & Rear Power Outlets
XJGS Non Locking Fuel Filler Cap
XKNP Flex Fuel Vehicle
XLNS English/USA Language
XVNP Basic Owner's Manual
X88S Tire & Wheel Parts Module
X9BP 1-Yr. SiriusXM Radio Service
YAAS Build To U.S. Mkt. Specifications
Thanks again for your email.
Sincerely,
Kristine
Customer Service Representative
Dodge Customer Assistance Center
Edited by jkeaton
Greetings,
- Are these the LEDs at the bottom of the door that shine on the ground? YES
- Does this mean my DRLs are on with high beam? NO.IT MEANS YOU HAVE DRL'S WHICH USE THE HIGH BEAM LAMPS DURING DAYTIME DRIVING
LPSS CHMSL Lamp
- What is this? NO IDEA
- Is this the stock steering? NO, UPGRADED FROM BASE MODEL
- Assuming this is the stock suspension? NO, UPGRADED FROM BASE MODEL BECAUSE YOU HAVE A CREW AND LARGER TIRES
- What are all these "X8*S" modules? THESE ARE THE COMMUNICATION MODULES ON THE CANBUS SYSTEM
- Where are X86S and X87S? DONT NEED OR DONT EXIST
- What is this? THE CODE FOR GROSS VEHICLE WEIGHT. SEE PLACARD ON INSIDE DRIVERS DOOR JAMB FOR MAXIMUM WEIGHT OF VEHICLE (PASSENGERS PLUS LUGGAGE)
Optional Equipment
Tire Pressure Monitoring System -- I think these three codes are related to the TPMS YES
X88S Tire Wheel Parts Module: I think this contains (among other things) the Sensor/WiFi Transmitters? COMMUNITCATION MODULE
CX8P CORA Tire Press Monitoring Sensor: I think this is the WiFi receiver? YES
XGMP Tire Pressure Monitoring Display: I think this is what presents data from the receiver to the EVIC display? YES
- I think this is to activate Sirius? YES
- I'm assuming these are suspension related? Why would these show under Optional Equipment? BECAUSE YOU HAVE THE TOURING SUSPENSION NOTED ABOVE. UPGRADED SPRINGS FROM BASE MODEL
- What on earth is this? MANUFACTURER TO DESTINATION. THE PATH OF WHERE IT CAME FROM AND WERE IT ENDED UP
2DLA Customer Preferred Package 2DL CREW OPTION PACKAGE
28L Customer Preferred Package 28L CREW OPTION PACKAGE,
- what are these?
Thanks,
Matthew
Same here. I thought it was an "SXT", Build sheet says "Dodge Journey Hero". Fopund this though, which pretty much explains it all:
"The new Dodge brand lifestyle models are aimed at consumers who want the most out of life rather than models that indicate only how much they were able to afford with the previous good, better and best lineup,” a Chrysler spokesman said via email about the name changes. “They are also intended to convey our new attitude.”
Srarting with the 2010 Dodge Journey:
There are more variations now available in terms of packages, which bundle options together. Currently, you can get an SE for $20,490, and the next step up to the SXT jumps to $23,790. The new variations have added three trims that fall between what was the SE and SXT.
Formerly
SE, SXT, R/T
Now
Dodge Journey (no trim level designation) $20,320 17-inch aluminum wheels, cruise control, sunscreen glass, body-colored mirrors, floormats and passenger grab handles.
Dodge Journey Express $21,320
Adds a two-person third row for seven-passenger seating
Dodge Journey Hero $22,320
Adds 235 hp, 3.5-liter V-6 engine with dual exhausts paired with a six-speed transmission
Dodge Journey Hero with AWD $23,320
Adds all-wheel drive, 19-inch wheels
Dodge Journey Heat $24,320
Adds Uconnect phone, iPod control, Sirius Satellite Radio, auto-dimming rearview mirror, remote start, trip computer, HomeLink universal transceiver, tonneau cover, six premium speakers with subwoofer, a tri-folding cargo floor with additional storage space beneath, 19-inch aluminum wheels and large chromed-tip dual exhausts
Dodge Journey Crew $25,320
Adds third row for seven-passenger seating, automatic climate control, premium gauge cluster, rear DVD entertainment system, 19-inch painted machined wheels, body-colored side sills and chrome interior accents, roof rack and door handles,
Dodge Journey Uptown $29,320
Adds leather-trimmed seven-passenger seating, power sunroof, navigation system with 30GB hard drive and real-time traffic, backup camera, rear DVD entertainment system, 19-inch chrome wheels and chrome bodyside molding
Edited by jkeaton
