larryl Posted November 7, 2013 Report Share Posted November 7, 2013 My 13 Crew with 11900 miles on it has been making a metal on metal clunk when shifting from Park to reverse or to drive or from reverse to drive and it has been getting worse. It didn't do it when it was new so I knew there had to be something going wrong Today it was quite bad so I took it to a dealer and when the service person came out to listen it did it for him also!!! So they put it up on the hoist and the problem from the factory was the "bolts" on the transmission hub were not properly torqued and had worked loose to the point where the hub was moving and causing the clunk. They torqued the bolts to spec and the noise and problem have been corrected So this might be something to look at if you are getting that kind noise Quote Link to comment Share on other sites More sharing options...
Hawaii Posted November 8, 2013 Report Share Posted November 8, 2013 My 13 Crew with 11900 miles on it has been making a metal on metal clunk when shifting from Park to reverse or to drive or from reverse to drive and it has been getting worse. It didn't do it when it was new so I knew there had to be something going wrong Today it was quite bad so I took it to a dealer and when the service person came out to listen it did it for him also!!! So they put it up on the hoist and the problem from the factory was the "bolts" on the transmission hub were not properly torqued and had worked loose to the point where the hub was moving and causing the clunk. They torqued the bolts to spec and the noise and problem have been corrected So this might be something to look at if you are getting that kind noise Interesting..... I have a 2013 with the 4 speed tranny with same symptoms. They said it was the mounts that were loose... Anyway, noise is gone. Quote Link to comment Share on other sites More sharing options...
dj cowboy Posted December 13, 2013 Report Share Posted December 13, 2013 My car started that today. It's going into the dealer tomarrow. It sounds like a chain banging against metal... Quote Link to comment Share on other sites More sharing options...
larryl Posted December 13, 2013 Author Report Share Posted December 13, 2013 Make sure they check the hub bolts Quote Link to comment Share on other sites More sharing options...
Trains123 Posted December 20, 2013 Report Share Posted December 20, 2013 My13 AWD did it when first bought it then stopped after 3000 miles. Don't do it at all any more. Quote Link to comment Share on other sites More sharing options...
Kendra Posted September 12, 2019 Report Share Posted September 12, 2019 My 2013 Has been doing a loud clunk as well, have taken it to many shops and just keep getting told the same thing, we cant find anything. So here I sit with over $4,000 stuck in this stupid thing and it still does it. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted September 12, 2019 Report Share Posted September 12, 2019 1 hour ago, Kendra said: My 2013 Has been doing a loud clunk as well, have taken it to many shops and just keep getting told the same thing, we cant find anything. So here I sit with over $4,000 stuck in this stupid thing and it still does it. They all do it. Mine did it for 4 years and 80,000 miles. Never had a problem though. I just learned to live with it. Quote Link to comment Share on other sites More sharing options...
2late4u Posted September 12, 2019 Report Share Posted September 12, 2019 1 hour ago, jkeaton said: They all do it. Mine did it for 4 years and 80,000 miles. Never had a problem though. I just learned to live with it. my 2014 did as well , actually i havent had it clunk in so long cant remember the last time it did. I did have the transmission fluid and filter done at 70 k early i know but just to be safe had it done anyways jkeaton 1 Quote Link to comment Share on other sites More sharing options...
km-04 Posted September 12, 2019 Report Share Posted September 12, 2019 My 2014 did as well. I looked it up and found that it was common. Still worried me so I took it to the dealer. They said it was the motor mounts, not sure if it was true, but the clunking stopped after that. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
