DarWrath Posted November 19, 2013 Report Share Posted November 19, 2013 Anyone have a clue where I might find some lowering springs for the 2014 sxt? I'd like to lower it an 1-1/2 or 2 inches without totally voiding the warranty. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted November 19, 2013 Report Share Posted November 19, 2013 They do not exist. Your best bet is to get the springs cut down maybe. Or a custom bagged set-up. Quote Link to comment Share on other sites More sharing options...
FROGBOX Posted November 20, 2013 Report Share Posted November 20, 2013 (edited) They do not exist..... Sure they do. H&R make a set of lowering springs for the Journey: 2WD part number: 50861 4WD part number: 50861-2 Google search shows they are available for just over $200. Here is a set on E-bay: http://www.ebay.com/itm/141103559835 Edited November 20, 2013 by FROGBOX Quote Link to comment Share on other sites More sharing options...
jkeaton Posted November 20, 2013 Report Share Posted November 20, 2013 Oh crap, my bad. I got confused. I think I meant a lift kit as I read where someone asked once about lifting their Journey and there was no lift kits to be found. Thanks for the correction. Quote Link to comment Share on other sites More sharing options...
DarWrath Posted November 23, 2013 Author Report Share Posted November 23, 2013 You're right the first time jkeaton, we tried the lowering springs for the 2011 til 2013, the back springs didn't fit currently, the front springs fit but once we lowered onto the springs it dropped to the wheel. Likely some one will come up with something that will work later next year. Quote Link to comment Share on other sites More sharing options...
Svehn Posted January 3, 2014 Report Share Posted January 3, 2014 I have a 2014 RT Ralleye and it sits about an inch lower than a standard Journey. Maybe if you got the springs from the Ralleye it would give you what you are looking for. Quote Link to comment Share on other sites More sharing options...
FROGBOX Posted January 16, 2014 Report Share Posted January 16, 2014 I have a 2014 RT Ralleye and it sits about an inch lower than a standard Journey. Maybe if you got the springs from the Ralleye it would give you what you are looking for. It appears that there are a LOT of choices for factory springs. About 26 different part numbers for the front springs alone. Each one probably has a slightly different spring rate based on the options on the vehicle that can affect the weight, such as engine size, 2WD vs AWD, 3rd row seating, etc. The part numbers can be found here: http://www.factorychryslerparts.com/showAssembly.aspx?ukey_assembly=1122913&ukey_make=1062&ukey_model=15496&modelYear=2013&ukey_category=20317&ukey_driveLine=10064&ukey_trimLevel=18652 I would guess that the sport suspension (aka euro suspension or high performance suspension) would be the lower ones you are looking for? The prices are quite reasonable at around $80 each for the fronts and $60 each for the rears. http://www.factorychryslerparts.com/showAssembly.aspx?ukey_assembly=1122919&ukey_make=1062&ukey_model=15496&modelYear=2013&ukey_category=20317&ukey_driveLine=10064&ukey_trimLevel=18652 Hope that helps. Quote Link to comment Share on other sites More sharing options...
Ric04SiR Posted January 17, 2014 Report Share Posted January 17, 2014 Don't know for the 2014 but here's a kit for the 2013 http://www.tirerack.com/suspension/suspension.jsp?make=H%26R&model=Sport+Spring+Set&group=Sport+Spring+Set&partNum=50861&autoMake=Dodge&autoModel=Journey&autoYear=2013&autoModClar=SXT Quote Link to comment Share on other sites More sharing options...
PhilsDodge Posted May 25, 2020 Report Share Posted May 25, 2020 Anyone ever find anything for these? I have been looking for a few hours haven't found something 100%. Quote Link to comment Share on other sites More sharing options...
jkeaton Posted May 26, 2020 Report Share Posted May 26, 2020 12 hours ago, PhilsDodge said: Anyone ever find anything for these? I have been looking for a few hours haven't found something 100%. 3rd post in this thread. Quote Link to comment Share on other sites More sharing options...
KnightRoller Posted November 19, 2020 Report Share Posted November 19, 2020 (edited) I'm curious about the link posted by FROGBOX as there are quite a few springs listed as "Euro High Performance Springs"...thats a lot of part numbers for the same spring? How can you tell the difference? Edited November 19, 2020 by KnightRoller Quote Link to comment Share on other sites More sharing options...
KnightRoller Posted November 19, 2020 Report Share Posted November 19, 2020 3 hours ago, Locosiete said: Hard to say since that post is 6 years old. Truth and real talk! But this isnt the only time I've run into this dilemma with Mopar parts. I would be nice if they were a bit more descriptive. The bad thing is if you call a dealer Part Dept most of those guys have no idea either. Oh for the Mopar parts Guru!! LOL Quote Link to comment Share on other sites More sharing options...
