My 2013 Dodge Journey only has 3100 miles. Want to know what type of oil the factory installed.
Manual says 5w20...but what type? Regular or synthetic?? It is a 1/2 quart low and want to make sure
it is the same as what is in it already. Not due for oil change as monitor has not gone off yet.
Thanks!
From your owners manual:
Engine Oil Viscosity – 3.6L Engine
SAE 5W-20 engine oil is recommended for all operating
temperatures. This engine oil improves low temperature
starting and vehicle fuel economy.
The engine oil filler cap also shows the recommended
engine oil viscosity for your engine. For information on
engine oil filler cap location, refer to the “Engine Compartment”
illustration in this section.
Synthetic Engine Oils
You may use synthetic engine oils provided the recommended
oil quality requirements are met, and the recommended
maintenance intervals for oil and filter changes
are followed.
7
MAINTAINING YOUR VEHICLE 533
Engine Oil – 3.6L Engine We recommend you use API Certified SAE 5W-20 Engine Oil, meeting
the requirements of Chrysler Material Standard MS-6395. Refer to your
engine oil filler cap for correct SAE grade.
Regular conventional oil is used but you can add or switch with synthetic.
Edited by Journey_SeXT
  On 12/17/2013 at 5:01 AM, redtomatoman said:
Interesting. The 2011 owner's manual states that 5-30 SAE oil is recommended. I wonder why they changed it?
Peace.
Hydraulic lifters bleed down over night, or while our Journeys are resting. 5w30 being a little thicker, doesn't get back to the top of the engine as quickly as 5w20 (hence the cold start clatter). That's why I am a believer in synthetic, it provides maximum lubrication even while an engine isn't being used. Its really the only drawback to a Variable Valve Timing engine.
My 12' says 5w20 so the 5w30 thing must be a first year bug.
  On 12/19/2013 at 2:35 PM, onecrazyfoo4u said:
My 2012 cap/manual say 5w-30...looks like they changed it mid-year. Mine was built in April 2012.
Now that I'm at 45k miles, I wonder if I should switch over to 5w-20? Technically that would be going against my manual though...
That's interesting, my 12' was built in August, so they must have swapped mid year as you stated. Mine also has the bigger updated brakes, and I have heard they did a swap on those mid year also. Seems odd to change things mid year, but better late than never I suppose...
Hard to say about changing oil viscosity now. Some folks might say "yes", and some folks might say "no", but the Pentastar hasn't been around long enough for anyone to truly know. I would say "if it ain't broke don't fix it". ;)
Has your dealer ever suggested to you to switch over to 5W-20? I would say stick with what your oil cap says to use as your engine was spec'd for 5W30. I think you're just going to make things more difficult to make a warranty claim if your engine experiences any issues and they tell you your warranty is now void due to wrong viscosity.
Good point. I haven't had any problems with 5w-30, so I'll just stick with what the cap says to avoid complication.
  • 2 weeks later...
