Tito Mon Posted December 19, 2013 Report Share Posted December 19, 2013 question guys..... If I switch my tire from front to rear and vice versa.. The tire monitoring gauge thus will change on my panel? And if I replace it from all season tire to winter tire.. Is that like a plug and play?if is not.. How to program it? Thanks... Quote Link to comment Share on other sites More sharing options...
redtomatoman Posted December 19, 2013 Report Share Posted December 19, 2013 Tire rotations will have no effect on your tire monitoring system (TPMS). It does not care which tire is where, it just monitors the pressure of the tires at each tire position. At least that is my understanding. If you put new tires on your same rims, there will be no effect on your TPMS. If you change rims, but do not put TPMS sensors on those rims, you will get a error in your EVIC. So if you change rims, you need TPMS sensors for those new rims. If you only change tires, you will not have to do anything. Peace. Quote Link to comment Share on other sites More sharing options...
larryl Posted December 19, 2013 Report Share Posted December 19, 2013 On my Crew I have no sensors in snow tires and all I get is N/A in the tire pressure screen no light on or anything a big improvement over my 09 Quote Link to comment Share on other sites More sharing options...
bramfrank Posted December 19, 2013 Report Share Posted December 19, 2013 (edited) Larryl is correct. Since 2011 the TPMS will give an error indication only for the first drive after the sensors are distanced from the vehicle and thereafter will show NA for the various wheel locations if you select the TPMS display. When you rotate your tires or re-install wheels with sensors the system will automatically figure out which wheel is where and will display pressures again. there is no dealer or manual intervention required. Note that the system does report in 1 PSI increments, so while essentially accurate, note that when in Metric the readout on the Journey is pretty coarse. The system in my old LHS was dead-on accurate and reported in centibar increments. Edited December 19, 2013 by bramfrank Quote Link to comment Share on other sites More sharing options...
wingit11 Posted December 19, 2013 Report Share Posted December 19, 2013 On 12/19/2013 at 2:26 PM, larryl said: On my Crew I have no sensors in snow tires and all I get is N/A in the tire pressure screen no light on or anything a big improvement over my 09 Like larryl said. When I had my '09 DJ you would have a warning light on all the time with the winters and no TPMS. Wife complained about the warning light so I covered it with a piece of black electrical tape till spring when I changed back to stock rims with TPMS. Now we have the '13 DJ, after the initial alarm warning it just indicates N/A when you go to tire pressure screen. Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCACares Posted December 19, 2013 Official Dodge Support Report Share Posted December 19, 2013 On 12/19/2013 at 3:15 PM, wingit11 said: Like larryl said. When I had my '09 DJ you would have a warning light on all the time with the winters and no TPMS. Wife complained about the warning light so I covered it with a piece of black electrical tape till spring when I changed back to stock rims with TPMS. Now we have the '13 DJ, after the initial alarm warning it just indicates N/A when you go to tire pressure screen. wingit11, Agreed, big improvement! Nothing a little electrical tape can't fix but that doesn't work for everyone, believe me.... Take care, Quote Link to comment Share on other sites More sharing options...
