guls Posted December 25, 2013 Report Share Posted December 25, 2013 Installed interior lighting in foot wells, center console, and in the back foot wells. Total cost less then $10. Pictures to follow. Quote Link to comment Share on other sites More sharing options...
davidlb512 Posted December 26, 2013 Report Share Posted December 26, 2013 Cool! Did you match the color, to the lights that are already inside? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted December 26, 2013 Report Share Posted December 26, 2013 Pics and how-to please. Quote Link to comment Share on other sites More sharing options...
guls Posted December 27, 2013 Author Report Share Posted December 27, 2013 Here are some pictures http://i952.photobucket.com/albums/ae10/ksport2/Journey/samsungpictures-1006_zps459081ce.jpg http://i952.photobucket.com/albums/ae10/ksport2/Journey/samsungpictures-1005_zps65d786fb.jpg http://i952.photobucket.com/albums/ae10/ksport2/Journey/samsungpictures-1004_zpsca8731da.jpg LEDs that I used are below, I used 4 LEDs (Blue Color) 1ea. in the front footwells, 1 in center console and 1 in the back side of center console for rear footwell areas. http://www.superbrightleds.com/moreinfo/led-wired-bolts/little-dot-smd-led-accent-light/639/ Quote Link to comment Share on other sites More sharing options...
guls Posted December 27, 2013 Author Report Share Posted December 27, 2013 Installation Steps: 1. First step is to find the Power source that is easiest to tap into. I wanted the LEDs to come on /off with the headlights at night and wanted them to dim with the dimmer switch. So easiest place was to tap into the headlight switch. 2. Remove the headlight switch, by turning it clockwise and pulling it out. See picture below. 3. The connector in the back- Black is ground and brown with Green stripe is Power. You can use any screw on the body as a ground. I just connected the positive wire here behind the switch to reduce the clutter. 4. For ease of access you have to remove the panel in next picture. 5. There are 2 bolts (I think 10mm) that you have to remove and then pins will pop out. There is a plastic screw/ clip, next to center console, I didn't mess with it I just let this hand down. Note: Don't worry airbag is at the bottom and you won't hurt it. Quote Link to comment Share on other sites More sharing options...
guls Posted December 27, 2013 Author Report Share Posted December 27, 2013 (edited) 6. Removing the back panel: Grab the back panel both sides at the bottom and pull it out. Disconnect the wiring Edited December 27, 2013 by guls Quote Link to comment Share on other sites More sharing options...
