ltdjourney Posted January 15, 2014 Report Share Posted January 15, 2014 Has anyone ever thought about installing third brake flashing module on your third brake light on Dodge Journey. Looks like it would be very easy to do but,I questioning intalling the module by wireing it into the wireing . any opinoins on this ,but I would like to do it to draw attiontion to drivers behind ????? Quote Link to comment Share on other sites More sharing options...
webslave Posted January 15, 2014 Report Share Posted January 15, 2014 I'll probably do it this spring. I traded a Hemi Commander in on my DJ and I had put one (flasher) on it. Easy mod and fairly effective, too. It caused the CHML to blink 5 times upon initial brake application and then remain lit as long as pressure was applied to the brakes. If you let off the brakes, but, got right back on them (<5 seconds) they wouldn't blink; that keeps folks behind you from getting annoyed in stop and go traffic. The CHML is a good idea, the flasher module makes it that much better, IMHO. Quote Link to comment Share on other sites More sharing options...
ltdjourney Posted January 26, 2014 Author Report Share Posted January 26, 2014 I'll probably do it this spring. I traded a Hemi Commander in on my DJ and I had put one (flasher) on it. Easy mod and fairly effective, too. It caused the CHML to blink 5 times upon initial brake application and then remain lit as long as pressure was applied to the brakes. If you let off the brakes, but, got right back on them (<5 seconds) they wouldn't blink; that keeps folks behind you from getting annoyed in stop and go traffic. The CHML is a good idea, the flasher module makes it that much better, IMHO. So I installed third brake light flashing module S--T don't work asked seller said that it's because of wireing from the Fiat group . So they have to come up with a different module ,but that's on a 2014 DJ it may work on eariler DJ'S ??? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted January 26, 2014 Report Share Posted January 26, 2014 Needs to work with canbus. Quote Link to comment Share on other sites More sharing options...
ltdjourney Posted January 27, 2014 Author Report Share Posted January 27, 2014 what's canbus it's already led lights ???? Quote Link to comment Share on other sites More sharing options...
bigtsr Posted January 27, 2014 Report Share Posted January 27, 2014 CANBUS is the propriety operating system that actuates all the electronics via data signals over the existing wiring,when you introduce an externally produced product to the system it has to be designed to work with these actuating signals i.e. turning them on/off. Yes the lights are already LEDs but this device is supposed to make them flash/cycle. jkeaton 1 Quote Link to comment Share on other sites More sharing options...
ltdjourney Posted January 27, 2014 Author Report Share Posted January 27, 2014 Thanks for ur reply Quote Link to comment Share on other sites More sharing options...
jkeaton Posted January 27, 2014 Report Share Posted January 27, 2014 Seller obviously has no clue if he is blaming it on the "wiring from the Fiat group"....Fiat had nothing to do with it. Quote Link to comment Share on other sites More sharing options...
ltdjourney Posted January 27, 2014 Author Report Share Posted January 27, 2014 kinded thought that but I don't know why only two wires on light ground and live can't go to wrong with hookup ???? Quote Link to comment Share on other sites More sharing options...
