2011 Mainstreet w/ 19" tires??
hartley62296
We bought a used 2011 Dodge Journey back in Sept., we were told it is a Mainstreet but it has 225/55/R19 tires on it and everything I read online says that the 2011 Mainstreet has 17" tires.
Is there a way to tell if it is mainstreet model or not?
Also we need to buy new tires for it and I am unsure who carries this size tire, can anyone recommend a place and/or tire?
We live in PA and another snowstorm is headed our way so we def. need good tires as this winter has been brutal.
Thanks for your help!
You can request your build sheet using this link. It will tell you everything about your vehicle.
http://www.dodge.com/webselfservice/dodge/emailpage.html?appStr=wccs&titleStr=Contact+Dodge&familyStr=brand&franchise=D&actionURL=%2Fwccs%2Fbrand_forms%2Fus%2Fwebform.jsp&promotion=null&category=U
Fill out all the required information.
Then in the area that says "Briefly describe" put "Vehicle Build Sheet" .
If you want to elaborate a little more as to why you want your build sheet, use the additional information area.
Search the internet for tire dealers in your area and call them to find out if they have tires your size in stock.
Edited by jkeaton
