dhh3 Posted October 4, 2014 Report Share Posted October 4, 2014 Every interior light in the 2014 is an LED except for the 2 on the lower portion of the rear hatch (not sure why those ones aren't). Map lights,cup holder, door pockets, underside of the door, etc... OIC. I am enlightened! Quote Link to comment Share on other sites More sharing options...
dethdeks Posted October 4, 2014 Author Report Share Posted October 4, 2014 dhh3 i havnt had a chance to yet as i'm in camp till thursday but will be able to after then. Quote Link to comment Share on other sites More sharing options...
dhh3 Posted October 11, 2014 Report Share Posted October 11, 2014 I'll wait for you to check you outboard lights before I attempt to remove the hatch interior panel. The bolts on each side of my 2014 are torx, but I'm not sure of the size. Quote Link to comment Share on other sites More sharing options...
dhh3 Posted October 13, 2014 Report Share Posted October 13, 2014 (edited) I thought that you meant that I had to remove the whole tailgate interior panel to get the lights out! Now, I reread your posts and see what you are talking about. FYI: they are 7mm, not 8mm. As I assumed, the inside connections are similar/same as the outside connections. The housing is also stamped 13.5v so the ballast for the LEDs is also in the housing. I'm betting that the connections are the same for either type of bulb. Let me know. Edited October 13, 2014 by dhh3 Quote Link to comment Share on other sites More sharing options...
dhh3 Posted October 15, 2014 Report Share Posted October 15, 2014 (edited) Did you guys all give up on switching out your lights, or are the harnesses different? Edited October 23, 2014 by dhh3 Quote Link to comment Share on other sites More sharing options...
