Lobitz68 Posted March 19, 2014 Report Share Posted March 19, 2014 Is there any difference between grilles on the 2009-2010 and the 2011-current DJ? Looking for something a little different, but the grilles I've been able to find seem to be broken up by years. Anyone know this answer for sure? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted March 19, 2014 Report Share Posted March 19, 2014 (edited) Yes. Earlier grills were solid chrome, or solid color, later ones have split with black bars in the middle of the "cross". http://www.thecarconnection.com/photos/dodge_journey_2009 http://usnews.rankingsandreviews.com/cars-trucks/Dodge_Journey/2013/photos-exterior/ Click on the front end view pictures in those links. Edited March 19, 2014 by jkeaton Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted March 20, 2014 Author Report Share Posted March 20, 2014 Perhaps I should have been more clear. I understand that they look different, but my question pertains more to shape... Could I take an aftermarket grille for a 2009-2010 and install it on my 2014? Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted March 20, 2014 Author Report Share Posted March 20, 2014 Yes. Earlier grills were solid chrome, or solid color, later ones have split with black bars in the middle of the "cross". http://www.thecarconnection.com/photos/dodge_journey_2009 http://usnews.rankingsandreviews.com/cars-trucks/Dodge_Journey/2013/photos-exterior/ Click on the front end view pictures in those links. The straight on pics are at a little different angle, but they look pretty similar in overall shape... I just don't want to drop $100+ on a part I can't use and that will be tough to get my money back on if I couldn't use it... Quote Link to comment Share on other sites More sharing options...
jkeaton Posted March 20, 2014 Report Share Posted March 20, 2014 Then I suggest a little more research is in order. Thats all I got. Quote Link to comment Share on other sites More sharing options...
DTSGUY Posted March 21, 2014 Report Share Posted March 21, 2014 I have a 2010 Journey and I put a 2012 Grill on mine and it fit perfectly. I also changed the lower grill and fog light inserts to match the honeycomb pattern. The picture I have on my profile shows the 2012 Grill but not the lower grill and fog light inserts cause I recently did those. My front lights are in the shop now getting done to look like the Black Top. When I get it back Ill post some pictures. Lobitz68 1 Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted March 21, 2014 Author Report Share Posted March 21, 2014 I have a 2010 Journey and I put a 2012 Grill on mine and it fit perfectly. I also changed the lower grill and fog light inserts to match the honeycomb pattern. The picture I have on my profile shows the 2012 Grill but not the lower grill and fog light inserts cause I recently did those. My front lights are in the shop now getting done to look like the Black Top. When I get it back Ill post some pictures. Are all of the mounting points the same? Good news for sure, thanks! Quote Link to comment Share on other sites More sharing options...
DTSGUY Posted March 21, 2014 Report Share Posted March 21, 2014 Are all of the mounting points the same? Good news for sure, thanks! Yes they are all the same. Its been a while since I did it but I do remember that I had to cut off a small plastic piece on the newer grill. The piece was in the back and wasnt anything cosmetic. It didn't change the integrity of anything. It took me about 20 min to do the swap out. Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted March 24, 2014 Author Report Share Posted March 24, 2014 Yes they are all the same. Its been a while since I did it but I do remember that I had to cut off a small plastic piece on the newer grill. The piece was in the back and wasnt anything cosmetic. It didn't change the integrity of anything. It took me about 20 min to do the swap out. What I am actually considering is a black one-piece billet grill. I believe that I would keep the same shell and just cut out the cross bars for this type of setup. The grille would then install inside that shell.... I'm still a little leery on pulling the trigger on this one though... Would be tough to get my money back on if it is the incorrect shape. Quote Link to comment Share on other sites More sharing options...
DTSGUY Posted March 24, 2014 Report Share Posted March 24, 2014 (edited) What I am actually considering is a black one-piece billet grill. I believe that I would keep the same shell and just cut out the cross bars for this type of setup. The grille would then install inside that shell.... I'm still a little leery on pulling the trigger on this one though... Would be tough to get my money back on if it is the incorrect shape. If you get another grill from another year it will fit. Even the 2014 grill is the same as the 2009 as far as the fit. Edited March 24, 2014 by DTSGUY Pat 1 Quote Link to comment Share on other sites More sharing options...
Pat Posted May 6, 2023 Report Share Posted May 6, 2023 Would a 2014 lower grille fit on a 2010? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted May 8, 2023 Report Share Posted May 8, 2023 On 5/5/2023 at 11:50 PM, Pat said: Would a 2014 lower grille fit on a 2010? If you look on ebay,., it appears that it will. 2010 dodge journey lower grill for sale | eBay Quote Link to comment Share on other sites More sharing options...
