toyau2 Posted March 26, 2014 Report Share Posted March 26, 2014 Hi I just brought my 2012 Journey in Febuary this year. There is a strange clicking noise coming from what sounds like the back left tire. I have a warranty and have been to the dealer 3 times for the same issue. I was checking online for recalls or others with the same problem when I ran into this forum. Is there any other Dodge Journey owners with the same problems? dhh3 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted March 26, 2014 Report Share Posted March 26, 2014 well if the clicking is coming from the front when you are turning a tight turn it would prob. be a cvc joint but from the rear dont know, i would try a different dealer the next time you take it in. dhh3 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted March 26, 2014 Report Share Posted March 26, 2014 (edited) Is it AWD? If so, I would suspect the CV joint. If not, jack up the rear end and spin the wheel and see if you can pinpoint where it's coming from. Has it always done it or just recently started? Is the noise noticeable inside or outside or both? Have you done any inspection of the wheel/tire/brakes? Edited March 26, 2014 by jkeaton dhh3 1 Quote Link to comment Share on other sites More sharing options...
Newjourney2014 Posted March 27, 2014 Report Share Posted March 27, 2014 I am having the same issue. My car is at the dear now, would you believe I only had the car for 4 weeks only 2014.. The car may return back to me tomorrow. I will update with the news. dhh3 1 Quote Link to comment Share on other sites More sharing options...
Newjourney2014 Posted March 28, 2014 Report Share Posted March 28, 2014 Will, I picked up my baby today and the problem was the brake clips was not lineup right per the dealer. No charge under warranty Now there is no more noise. dhh3 and Journey_SeXT 2 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted March 28, 2014 Report Share Posted March 28, 2014 Sometimes it's the simple things. Journey_SeXT and dhh3 2 Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted March 28, 2014 Official Dodge Support Report Share Posted March 28, 2014 Will, I picked up my baby today and the problem was the brake clips was not lineup right per the dealer. No charge under warranty Now there is no more noise. Glad to hear the issue was resolved. Enjoy your new Journey. Regina U.S. Top Care Chrysler Group LLC dhh3 and jkeaton 2 Quote Link to comment Share on other sites More sharing options...
Official Dodge Support DodgeCares Posted March 28, 2014 Official Dodge Support Report Share Posted March 28, 2014 Hi I just brought my 2012 Journey in Febuary this year. There is a strange clicking noise coming from what sounds like the back left tire. I have a warranty and have been to the dealer 3 times for the same issue. I was checking online for recalls or others with the same problem when I ran into this forum. Is there any other Dodge Journey owners with the same problems? I am sorry to hear that the clicking noise is not resolved. Did the dealer verify the noise and make any repairs? You can take your vehicle to another dealer for diagnosis. Please keep us posted. dhh3 1 Quote Link to comment Share on other sites More sharing options...
Tammy Woods Posted August 26, 2016 Report Share Posted August 26, 2016 2011 Dodge Journey Mainstreet, purchased used... 30 day warranty long gone. The noise I hear is more of a clanking noise rather then clicking. Sounds like metal on metal and stops when I tap the brake. It also stops when I get up some speed . 30mph or over. Sometimes its not even there. I have not taken it to the shop because I dont have the money to do so right now. Any ideas? dhh3 1 Quote Link to comment Share on other sites More sharing options...
2late4u Posted August 26, 2016 Report Share Posted August 26, 2016 front or rear where does the noise sound likeit is coming from? put it up on jacks all 4 wheels in case you have awd then turn the car on put the wheels in motion and listen at each wheel for noise, you could go to most brake shops they usually will check your vec. for free just hoping they find something so they can fix it. just get a price if they tell you what is wrong first so you know what it will cost. good luck dhh3 1 Quote Link to comment Share on other sites More sharing options...
jkeaton Posted August 26, 2016 Report Share Posted August 26, 2016 This ^^. Jack it up and try to isolate the sound. It could be anything. If you can't do this, brake places or independent shops normally wont charge you to diagnose an issue. dhh3 1 Quote Link to comment Share on other sites More sharing options...
JohnnyRevs Posted November 3, 2016 Report Share Posted November 3, 2016 On 8/26/2016 at 0:45 PM, Tammy Woods said: 2011 Dodge Journey Mainstreet, purchased used... 30 day warranty long gone. The noise I hear is more of a clanking noise rather then clicking. Sounds like metal on metal and stops when I tap the brake. It also stops when I get up some speed . 30mph or over. Sometimes its not even there. I have not taken it to the shop because I dont have the money to do so right now. Any ideas? Hi Tammy, apologies, coming to this late so maybe you have this sorted by now? I had this problem on my Journey but it turned out to be just the copper shims that sit on the brake caliper. They allow the brake pad to easily move in an out and also keeps them under tension to stop them vibrating in place. I had the same symptoms in that it rattled around when driving at slower speeds but disappeared when braking and at higher speed - I suppose that the pressure of the brake piston under braking keeps them from rattling around so the noise disappears and at higher speeds, either I just couldn't hear them or perhaps the higher speeds somehow kept them in position? The shims are gently sprung to keep them in place but I guess mine became lose and popped out. They were only around €10 (prob $10 for you) for a couple of sets (i wanted a few spares). Hopefully, you got you problem sorted but please post back to let the rest of us know! Quote Link to comment Share on other sites More sharing options...
