No sound from radio
Occasionally after start-up, there will be no sound from radio. Can change stations and bands but acts like volume is turned off. Turn ignition off and restart engine and it will be fine. My DJ is a 2012 with 38000 miles. Recently bought used. Love the car and hoping someone might have an idea why radio does this.
It seems to be an odd CANBUS issue. I've had this happen in my van a couple times. I've also had it be at like 25% volume (so full blast is barely audible). It is very rare that it happens, but it does happen.
Perhaps there's a software patch for it?
Mine is no sound at all... Tried turning off and on engine to resat but still not working.. Semms like the volume is off but eventough you turn up volume still no sound at all.. We ca n play any song on usb track time is moving but no sound at all same thing on radio. Also on my navigation it used to speak turns but now its all nothing! Any idea as what is the problem??? Thanks!
  • Official Dodge Support
I could be wrong but I seem to recall this problem before and
the solution was pulling and resetting a fuse for the amp.
bigtsr,
I've been able to identify multiple radio enhancements which may address the concern, certainly wouldn't hurt to check the appropriate fuse either.
I'd recommend having the vehicle into a Dodge Service Facility if anyone is having radio related issues. The Dealer Network has been provided quite a few software updates for issues similar to this.
I had this issue where NO sound was coming out, but the radio was on. I unplugged the amp wire under the passenger seat (wires with white end caps) and once plugged back in the sound worked perfectly! Give it a try. My dealership wanted to charge me to look into it, and my warranty is over! Too expensive!
