Phill Tomlinson Posted April 13, 2014 Report Share Posted April 13, 2014 I would like to remove the single seat of the 60/40 2nd row seat. How can I do this? Quote Link to comment Share on other sites More sharing options...
nvdale Posted April 13, 2014 Report Share Posted April 13, 2014 Not a problem. Just remove the three bolts and one nut under the seat. I removed both of mine to make more room for a road trip. Together they must weigh 150 lbs. surveillancejourney and Phill Tomlinson 2 Quote Link to comment Share on other sites More sharing options...
Edi Posted May 24, 2014 Report Share Posted May 24, 2014 Hi there my seat is stuck i can only see the bolts at the back where is the other bolt and the nut? Thx Quote Link to comment Share on other sites More sharing options...
jkeaton Posted May 25, 2014 Report Share Posted May 25, 2014 Hi there my seat is stuck i can only see the bolts at the back where is the other bolt and the nut? Thx In the front. Quote Link to comment Share on other sites More sharing options...
surveillancejourney Posted October 25, 2014 Report Share Posted October 25, 2014 Can you post pictures? Is it easy to reinstall? Quote Link to comment Share on other sites More sharing options...
jkeaton Posted October 25, 2014 Report Share Posted October 25, 2014 Pop the plastic cover off at the front mounting point, the bolt is under there. Reinstall is reverse of removal. Quote Link to comment Share on other sites More sharing options...
Milous Posted October 26, 2014 Report Share Posted October 26, 2014 Ideally, when re-installing the 2nd row seats: Tighten all four seat track to floor fasteners to 95 Nm (70 ft. lbs.) in the following sequence: a. Front inboard bolt b. Front outboard bolt c. Rear inboard nut d. Rear outboard bolt (the above procedure will result in easier fore/aft movemnet of the seats). Kubda, Lobitz68 and jkeaton 3 Quote Link to comment Share on other sites More sharing options...
Lobitz68 Posted October 27, 2014 Report Share Posted October 27, 2014 Ideally, when re-installing the 2nd row seats: Tighten all four seat track to floor fasteners to 95 Nm (70 ft. lbs.) in the following sequence: a. Front inboard bolt b. Front outboard bolt c. Rear inboard nut d. Rear outboard bolt (the above procedure will result in easier fore/aft movemnet of the seats). good info. thanks! jkeaton 1 Quote Link to comment Share on other sites More sharing options...
surveillancejourney Posted September 11, 2015 Report Share Posted September 11, 2015 Not a problem. Just remove the three bolts and one nut under the seat. I removed both of mine to make more room for a road trip. Together they must weigh 150 lbs. Quote Link to comment Share on other sites More sharing options...
surveillancejourney Posted September 11, 2015 Report Share Posted September 11, 2015 Can you post pictures of your second row seats removed? Quote Link to comment Share on other sites More sharing options...
larryl Posted March 8, 2016 Report Share Posted March 8, 2016 96 Astro hahaha Quote Link to comment Share on other sites More sharing options...
